82 kz1100 speedometer and odometer quit working and tach has been jumpy 16 Apr 2023 14:24 #883267
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
  • Thank you received: 34
so the speedometer is the electronic pulse type
recently quit working and thought it was the speed sensor however not the case
my fsm tells me to check the 3-pin and 6-pin connectors in headlamp case
these connectors are very adhered and stuck together, anyone have any tips on how to get 'em apart?
i did manage to check for battery voltage at the 3-pin speedo sensor connector - wht from male side and blk/yell from female side
with key on - no voltage
which wire in loom under tank feeds power to the odom, speedo, and tach? from what i see it's either orange or brown but not sure
also, noticed the orange odometer lead has no voltage either.
are these items related to the 10 amp horn fuse?
any ideas or thoughts, please chime in.
much thanx
1982 KZ1100D1
82 kz1100 speedometer and odometer quit working and tach has been jumpy 16 Apr 2023 18:29 #883286
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
Twenty-three years owning my 1100 have taught me to plow into problems and take chances.  If something breaks, then oh well...there's ebay.
Thing is, these bikes are tough.  They were made in Japan, not China.
Thank God.  Go for it!
1982 KZ1100-A2
82 kz1100 speedometer and odometer quit working and tach has been jumpy 17 Apr 2023 10:53 #883347
  • Gdailey2112
  • 82 KZ1100D1
so very true daveo
well now i have voltage at the 3-pin speedo sensor and it seems my odometer is at least rolling numbers same with trip meter, however the orange lead from odometer shows no volts
and from what i assume, is that the orange lead from OD then powers the speedo? i dunno but that's what it looks like on the diagram
1982 KZ1100D1
82 kz1100 speedometer and odometer quit working and tach has been jumpy 17 Apr 2023 10:58 #883350
  • Gdailey2112
  • 82 KZ1100D1
wookie wookie where are you lol
1982 KZ1100D1
82 kz1100 speedometer and odometer quit working and tach has been jumpy 17 Apr 2023 11:01 #883353
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 444
Wooookeeeeeee
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
82 kz1100 speedometer and odometer quit working and tach has been jumpy 17 Apr 2023 11:04 #883354
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1923
Will try and look at a wiring diagram later or tomorrow
82 kz1100 speedometer and odometer quit working and tach has been jumpy 17 Apr 2023 17:01 #883371
  • Gdailey2112
  • 82 KZ1100D1
thank you wookie!
1982 KZ1100D1
82 kz1100 speedometer and odometer quit working and tach has been jumpy 17 Apr 2023 17:54 #883375
  • daveo
  • daveo's Avatar
  • Premium Member
I seem to recall a poor yellow/black ground wire connection behind a left-side ignition coil mount bolt was causing a minor tach-needle fluctuation some dozen years or so ago.
A wire brushing took care of that.
1982 KZ1100-A2
The following user(s) said Thank You: Gdailey2112
82 kz1100 speedometer and odometer quit working and tach has been jumpy 18 Apr 2023 01:46 #883387
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Can you clarify which model you have, your previous posts refer to a 82 KZ1100 and a 82 GPZ1100 is it a KZ1100A? or a KZ1100 B1/B2 ? Vin number would be useful. Also can you post a picture of which instruments you have ?
Also ref the "jumpy" tach, I see you have an old post on this issue - was it resolved at that time or has it been an on-going issue ?
Last edit: by Wookie58.
82 kz1100 speedometer and odometer quit working and tach has been jumpy 19 Apr 2023 12:33 #883446
  • Gdailey2112
  • 82 KZ1100D1
yes i thought it was a gpz but the further i looked into it seems it's a d1 model, or 1100d1 specter
daveo - i will certainly try that, thanx
1982 KZ1100D1
82 kz1100 speedometer and odometer quit working and tach has been jumpy 19 Apr 2023 12:39 #883447
  • Gdailey2112
  • 82 KZ1100D1
does the orange wire feed signal/pulse?
1982 KZ1100D1
82 kz1100 speedometer and odometer quit working and tach has been jumpy 19 Apr 2023 12:57 #883451
  • Wookie58
  • Wookie58's Avatar
  • Moderator
The orange is the speed signal, now I know which diagram to look at I will put something together for you (didn't want to send you down a rabbit hole with bad info  )
