1977 kz650 regulator rectifier upgrade
  • vict182
  • vict182's Avatar Topic Author
Re: 1977 kz650 regulator rectifier upgrade
19 Nov 2022 06:28 - 19 Nov 2022 06:32
#876968
Thank you for all the replies
Keeping in mind this regulator should be easy and cheap, the solution of buying one from the states isn't easy and cheap for me, so i kept studying the subject and i found something interesting...
The system with field coil isnt that forgotten since 1977, seems many automotive generators still use this system and so they have the same regulation and rectifier system
But i suddenly came to a stop on this directidirection when my curiosity took me on the workshop manual of my 2005 kawasaki zrx1200
Guess what. Its generator has the field coil system and separate regulator and rectifier
Prices of genuine reg and rec are crazy about 399 each
But i found an argentinian company which makes those regulator easy and simple for few bucks, they sell parts also in italy so i could buy one regulator from an italian seller on ebay for 25euros which is about 30dollars i guess, no customs, no forever waiting...
I will give it a try and get back to you if you're curious too
probably i will fry the whole motorbike but well this is the risk we all take for experiments and improvements isn't it?
Last edit: 19 Nov 2022 06:32 by vict182.
  • martin_csr
  • martin_csr's Avatar
19 Nov 2022 07:53 - 20 Nov 2022 07:23
#876971
You might be able to find the parts at a motorcycle salvage yard.
The cross-reference at Partzilla shows a number of other models came with the same parts as the ZRX.
Other non-KZ models also had a separate rectifier & voltage regulator. In the links below click the parts for the x-ref.
Cmsnl.com has diagrams for some Euro models & also has a cross-reference. Cmsnl is in the UK.
2005 ZRX1200-A5:
www.partzilla.com/catalog/kawasaki/motor...-zr1200-a5/generator
1986 ZG1000-A1 Concours:
www.partzilla.com/catalog/kawasaki/motor...-zg1000-a1/generator
Cmsnl.com Kawasaki page:
www.cmsnl.com/kawasaki_model11368/
Last edit: 20 Nov 2022 07:23 by martin_csr.
  • stone fruit
  • stone fruit's Avatar
21 Nov 2022 17:10
#877058
I've been using one from Z!E for over ten years now and no problems whatsoever.
I realize you aren't keen to buy from the US but I'm in Australia and have to get most of my parts imported. Never had a problem buying from overseas.
www.z1enterprises.com/yamaha-xs650-unive...Z650/all-models/1977
  • Feanor_twh
  • Feanor_twh's Avatar
23 Nov 2022 09:54
#877097
I recommend that you take a look at Oregon motorcycle Parts .
There I bought the electronic regulator for my KZ400, a great piece that is also configurable to charge Lithium batteries. I also bought the rectifier (which was fried). It wasn't particularly cheap but I haven't had to worry since.
(1976) Kawasaki KZ400-D3. All original, but: electronic reg/rec (Oregon Motorcycle Parts), new handlebar controls (w/ PASS/HORN/lights switch, LED dash lights (superbrightleds.com), Dynatek coil (3ohm), MAC mufflers, HEL brake hoses, rubber fork boots, 4.00 rear tyre (Dunlop K70), chromed chainguard
22 Feb 2023 03:02
#880621
Glad you found a solution, I´m having this kind of issues as well. I tried Lou's regulator as well but I have not been able to make it work properly,
Did you have success?
24 Aug 2024 15:14
#903628
Hi,
After a lot of research I found out that the original voltage regulator can be easily replaced for an automotive one.
I have succesfully used the EC CARGO 136325 part which has a potentiometer to adjust the output voltage and is widely available (it cost me 10 euros).
Good luck!
