  • Page:
  • 1
  • 2
81-82 KZ1100A Meter “Damper” 20 Aug 2022 06:20 #872527
  • AmStaFF
  • AmStaFF's Avatar Topic Author
  • Thank you received: 5
Does any inmate know of a source or substitute for replacing the rubber isolating gasket between the speedo/tach and the mounting cup?
Attachment not found
1981 KZ1100A
2013 Moto Guzzi Griso
2020 Moto Guzzi V85TT
2021 Husq FE350
81-82 KZ1100A Meter “Damper” 20 Aug 2022 06:22 #872528
  • AmStaFF
1981 KZ1100A
2021 Husq FE350
81-82 KZ1100A Meter “Damper” 20 Aug 2022 06:58 #872530
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
Meter damper substitute for 92075-1315 >> windshield wiper blade. Linked topic below has good pics.
Topic title = 1981 KZ1000 Speedo/Tach Rubber damper alternative by EksCelle:
www.kzrider.com/forum/4-electrical/61290...r-alternative#823762
Last edit: by martin_csr.
81-82 KZ1100A Meter “Damper” 20 Aug 2022 07:50 #872532
  • Moose1800
  • Moose1800's Avatar
  • Thank you received: 256
Meter damper substitute for 92075-1315 >> windshield wiper blade. Has good pics.
That's what I call thinking outside the box !
81-82 KZ1100A Meter “Damper” 21 Aug 2022 04:34 #872587
  • AmStaFF
Great, Guys! Thanks. That new  part number, 92075-1315, brings up good info also. Seems there might still be a guy in Australia that makes reproductions. A little pricey though at $53 w/shipping.
1981 KZ1100A
2021 Husq FE350
81-82 KZ1100A Meter “Damper” 22 Aug 2022 05:21 #872641
  • martin_csr
I could be wrong, but I think the guy in Australia doesn't make them anymore (Nippon Nirishi or something like that).
81-82 KZ1100A Meter “Damper” 22 Aug 2022 10:05 #872647
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 351
81-KZ440-D2.
LIC, NY
81-82 KZ1100A Meter “Damper” 22 Aug 2022 11:47 #872648
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
  • Thank you received: 34
www.mcmaster.com/door-weatherstripping/
awesome! that link helps with a few other projects as well
thank you
1982 KZ1100D1
81-82 KZ1100A Meter “Damper” 22 Aug 2022 12:33 #872649
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 512
Looks like you could use a vacuum cleaner beater bar belt, i just changed one it was about 1/2" wide x 1/8" thick any type of rubber belt? Or Macgyver Fix!!!
81-82 KZ1100A Meter “Damper” 22 Aug 2022 15:17 #872655
  • AmStaFF
The fellow in Australia still sells them,and Sent a PayPal invoice ….
1981 KZ1100A
2021 Husq FE350
Last edit: by AmStaFF.
81-82 KZ1100A Meter “Damper” 23 Aug 2022 03:59 #872672
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 431
That part is a perfect candidate for 3D-printing... If I had measurements, I could model it, and be done printing in a few minutes, using a material called TPE (Thermo Plastic Elastomer).
It is pretty cheap @ $15 per pound, so that part will cost no more than 50 cents !
I have successfully printed turn signal vibration isolation "rubbers", tail-light gaskets, seat mounting blocks, float-bowl gaskets, pet-cock seals, air-box snorkel etc.
If you could post measurements here, I will draw it and post the 3D print-model for you, for free!
Just send the file to your nearest 3-D print shop.
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
The following user(s) said Thank You: Mikaw, Wookie58
Last edit: by howardhb.
81-82 KZ1100A Meter “Damper” 23 Aug 2022 04:54 #872675
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Page:
  • 1
  • 2
