  • Page:
  • 1
  • 2
Ignition by-pass relay W 04 Jan 2024 10:46 #893567
  • TheTrout
  • TheTrout's Avatar
  • Thank you received: 55
I did this mod well over 10 years ago.  At one time I thought the relay was going bad, bought a new one, but that was not it.  It probably the dyna coils shorting to the mounting stud.  Later I read here about shrink wrapping the studs to avoid that.  My bike starts with no issues and quickly.  The relay and fuses are under the left side cover.
1978 KZ1000B2
Ignition by-pass relay W 04 Jan 2024 16:47 #893596
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 85
Yes a lot of guys make the mistake not insulating the round studs. The first time I mounted the Dyna coils I looked and said, O only a few thousand clearance that ain't going to work. I now use nylon spacers.
Ignition by-pass relay W 05 Jan 2024 05:52 #893616
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Away
  • Thank you received: 606
To build on WOOKIE58's OP, a common voltage drop culprit is often the ignition switch itself.  If voltage at the coil primary isn't at or very close to battery voltage, a bypass relay mod is well worth it.
The link below is a deep dive through the cobwebs & into the rabbit hole that is an OEM Z1 ignition switch.  Although we were chasing an intermittent issue, the cause of voltage drop across the ignition switch also became clear once we saw its innards.
kzrider.com/forum/4-electrical/606810-z-...-and-troubleshooting
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
The following user(s) said Thank You: Wookie58, motomisfit
Last edit: by slmjim+Z1BEBE.
Ignition by-pass relay W 05 Jan 2024 08:32 #893627
  • motomisfit
  • motomisfit's Avatar
  • Thank you received: 49
Excellent read! Thank you for that link.
Ignition by-pass relay W 06 Jan 2024 14:42 #893696
  • motomisfit
Bypass switch installed. I thought I’d post a pic so others could see one installed. Painstaking but I’m a firm believer now that this mod is a good thing to do.
The following user(s) said Thank You: ThatGPzGuy, sf4t7, Wookie58
Last edit: by motomisfit.
  • Page:
  • 1
  • 2
