  • Page:
  • 1
kawasaki sh232-12 electrical voltage rectifier regulator 23 Nov 2021 12:52 #858256
  • willemZ900
  • willemZ900's Avatar Topic Author
  • Z1B 4 ever
  • Thank you received: 52
Question about the kawasaki SH232-12 electrical voltage rectifier regulator, can this type be changed by the SH532 -12 or not?
Connector and colors are the same!
kawasaki sh232-12 electrical voltage rectifier regulator 24 Nov 2021 07:25 #858287
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Most likely yes. The 532 came from a police bike maybe? It's possibly meant to handle more power than the 230 series, I'm guessing.
Any more -modern, from the 2000's, Kawasaki factory reg/rec with three yellow, one red, one black, and one brown wire should swap with any other one. The connectors may differ, requiring splicing wires, though.
The following user(s) said Thank You: willemZ900
Last edit: by loudhvx.
kawasaki sh232-12 electrical voltage rectifier regulator 24 Nov 2021 12:47 #858297
  • JR
  • JR's Avatar
  • Thank you received: 429
I have 1980 KZ750e1
A few years back I swapped out the old SH230-12 for a newer SH530-12 from an 05 or 06  EX500 Works just fine
The connector block on the newer unit was female and on the old was male . Not a big deal to fix
The following user(s) said Thank You: willemZ900, Mikaw
kawasaki sh232-12 electrical voltage rectifier regulator 25 Nov 2021 14:43 #858331
  • Ojisan rider
  • Ojisan rider's Avatar
  • Thank you received: 63
I'm not sure if this helps, but my bike came with 530 series and it's an 82 750. Wiring seems to be all the same.
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
kawasaki sh232-12 electrical voltage rectifier regulator 27 Nov 2021 00:34 #858360
  • willemZ900
  • Z1B 4 ever
Thanks to all, just bought a used SH530 with same colors and connector
  • Page:
  • 1
