  • Page:
  • 1
  • 2
change out ignition on a 1975 KZ400 kick only and simple diagram 09 Oct 2021 22:14 #856477
  • bcfox0630
  • bcfox0630's Avatar Topic Author
  • Thank you received: 0
i really need some help. im new to building motorcycles on my own. im a machinist but this is my first wiring job and first bike that i got that wasnt running yet. i have a 1975 kz400. I need to switch out the ignition (he didnt have the keys, and the toggle switch that is up front goes a couple wires to headlight but there are wires with connectors on them but some were dissconnected and i dont know what to do. i really need help. by the way thisa is kick only bike. please help!!!!!
change out ignition on a 1975 KZ400 kick only and simple diagram 10 Oct 2021 15:25 #856511
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 369
If I am correct there were 2 different versions of the 400 offered in 75.  The D model with electric start and I think a disk front break.  The second offered was a S model with not electric start, a drum front brake and a 2 into 1 exhaust.  The wiring system is pretty much the same, except for the starter system. Do you have access to wiring diagrams here are ones for the S and one for the D model.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: bcfox0630
change out ignition on a 1975 KZ400 kick only and simple diagram 10 Oct 2021 21:24 #856523
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Here is a digital, searchable factory service manual.
www.kzrider.com/modules/ServiceManuals/7...chablefullmanual.pdf
change out ignition on a 1975 KZ400 kick only and simple diagram 11 Oct 2021 10:06 #856533
  • bcfox0630
it says this browser does not support PDF's. thanks anyways
change out ignition on a 1975 KZ400 kick only and simple diagram 11 Oct 2021 10:39 #856534
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
The KZ400.com site has a manual & wiring diagrams (diagrams in the Technical tips section).
Warning: do not go into the forums as they may harm your computer.
I guess this is still true about the forums. The site didn't have an administrator, hence the problems .
Simplified wiring diagrams:  search KZR for Bare Bones for Mattylight >> topic by loudhvx.
Some of them are missing, but there's probably one or two you can use.
Last edit: by martin_csr.
change out ignition on a 1975 KZ400 kick only and simple diagram 11 Oct 2021 21:01 #856538
  • TexasKZ
  • TexasKZ's Avatar
If you go to the top of this page and open the Articles menu, then choose Service Manuals, you can download it yourself.
change out ignition on a 1975 KZ400 kick only and simple diagram 12 Oct 2021 07:36 #856547
  • martin_csr
By TexasKZ:  If you go to the top of this page and open the Articles menu, then choose Service Manuals, you can download it yourself.
Makes perfect sense.  why would anyone try the Filebase.  ps: no wonder I've never been able to find a manual here on KZR. doh.
change out ignition on a 1975 KZ400 kick only and simple diagram 12 Oct 2021 13:26 #856555
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
This is a copy of the PM I replied with.
There are a few simplified Kz400 diagrams in the "Mattylight bare bones" thread.
Here are two you can look at... (Private messages don't carry live links so you have to copy and paste the links into your address bar).
www.kzrider.com/forum/4-electrical/17274...ght?start=444#807723
www.kzrider.com/forum/4-electrical/17274...ght?start=372#703075
If it's kick-only, you can use pretty much any small, 12v, scooter battery.
Last edit: by loudhvx.
change out ignition on a 1975 KZ400 kick only and simple diagram 13 Oct 2021 07:39 #856585
  • bcfox0630
also have one more question. i have a different ignition and i dont know what wires go to what pronges? Here are some pics of how it was wired and my new one?
the brown,blue,red,and yellow are hooked to the "A" and the white is hooked on "B" on old ignition. how do i put these on new ignition?
change out ignition on a 1975 KZ400 kick only and simple diagram 13 Oct 2021 12:36 #856600
  • gd4now
  • gd4now's Avatar
From the pic of the old key switch I am unsure of what the yellow wire is.  I can not see it noted on the wiring diagram(s) posted or I have access to. Do you have a volt ohm meter or a test light to see which post does what when you turn the key.
1977 KZ650 B1
This is my Z
change out ignition on a 1975 KZ400 kick only and simple diagram 13 Oct 2021 15:53 #856604
  • loudhvx
  • loudhvx's Avatar
That is someone's custom wiring.  You should trace it out or just replace it.  If I had to guess, I would assume red was for the tail light, blue is for the headlight, and yellow was to the ignition coil to power the ignition system.  But that's a wild-ass guess and would need to be verified with a continuity test.
The way it was previously wired, the red, yellow, and blue all go to one terminal so they would on the new switch as well.  Put those three wires on the terminal marked IGN.  The other wire you have would go to the BATT terminal.
If on the old switch, you have a white wire and a brown wire going to the same terminal (I can't tell by the photo), and the wire colors are the same as a stock bike, that would be a wiring error.  White is usually un-switched 12v and brown is usually switched 12v.  They should not just be hardwired together unless other changes were done.
Also, as a side note: Those aftermarket ignitions like that in the first photo, tend to be unreliable.  Vibration seems to make them come apart in a short time.  Just keep an eye on it.
change out ignition on a 1975 KZ400 kick only and simple diagram 13 Oct 2021 16:36 #856606
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2675
Most modern browsers have an extension you can add in order to view a PDF file.  Or, get Adobe PDF viewer.  It's free.
  • Page:
  • 1
  • 2
