  • Page:
  • 1
Where to buy KZ750 H Stock Fuses? 03 Aug 2021 11:09 #853077
  • d4rkmatter
  • d4rkmatter's Avatar Topic Author
  • Thank you received: 1
I've been trying to track down somewhere that sells the correct fuse size for the KZ's and haven't had any luck.
Seems everything available at auto stores is too small.
Anyone got a go to spot?
Where to buy KZ750 H Stock Fuses? 03 Aug 2021 12:32 #853085
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1843
Where to buy KZ750 H Stock Fuses? 04 Aug 2021 06:45 #853133
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1620
For the main fuse box you can get AGX fuses (1/4" x 1"): 20A & 10A.
The acc fuse box uses AGC fuses (1/4" x 1-1/4"): 10A.  (assuming your Ltd has the acc. it helps to mention the year).
Last edit: by martin_csr.
Where to buy KZ750 H Stock Fuses? 04 Aug 2021 07:53 #853137
  • d4rkmatter
Year is 1981.
I cant seem to find AGX fuses at any local auto shops. Weird.
I ordered some off Z1 but was hoping there was somewhere local.
Where to buy KZ750 H Stock Fuses? 04 Aug 2021 09:24 #853140
  • martin_csr
Glass fuses are getting hard to come by (locally in stores).  Most auto parts stores nowadays don't have much, usually a variety pack which usually includes a bunch of unneeded sizes.
The following user(s) said Thank You: d4rkmatter
Where to buy KZ750 H Stock Fuses? 04 Aug 2021 10:19 #853143
  • Thank you received: 2828
There are MANY glass fuses available on eBay.  AGX, AGC, etc.  Ed
Where to buy KZ750 H Stock Fuses? 04 Aug 2021 11:30 #853148
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 362
I went this route to avoid the Buss fuse availability issue:
The block itself was about $7 on Amazon.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Where to buy KZ750 H Stock Fuses? 09 Aug 2021 09:49 #853450
  • xstreamcanadian
  • xstreamcanadian's Avatar
  • Thank you received: 4
I hope you put some heat shrink over those connectors. Thats a short waiting to happen.,
Where to buy KZ750 H Stock Fuses? 09 Aug 2021 16:44 #853474
  • Nerdy
  • Nerdy's Avatar
Not if the fuse box is in its own housing.
The airbox is gone; the battery and other electrics will live in their own enclosure between the frame tubes.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
  • Page:
  • 1
