  • Page:
  • 1
  • 2
spark plug boots 20 Jul 2021 13:59 #852136
  • motoaddict
  • motoaddict's Avatar Topic Author
  • Thank you received: 8
Hi gang, So today I went to check the plugs on this old girl (76 KZ900) and when I pulled the first boot it popped off the wire like it wasn't even attached. What is the direction I should take here. Do I just cut the jacket back and exposed new wire? Should I get new boots? The old ones are lookin pretty crusty inside. What are my aftermarket options? Cheers!
1976 KZ900
Last edit: by motoaddict.
spark plug boots 20 Jul 2021 14:41 #852140
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
If you want to keep the OEM coils you choices are limited. If you have enough length, you can cut them back a smidge at a time to expose clean core wire. Then you can get new NGK caps. I’ve seen HT wire couplers. I have no experience with them but they could be an option to replace the plug wires. Other than that new coils are your only other option. Make sure you get 3 or 4 ohm coils. Factory spec is 3.2~3.8 primary ohms. DynaTek makes 3 and 5 ohms. As far as I know either are fine.
spark plug boots 20 Jul 2021 14:42 #852141
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2067
I say cut back just a little bit, and install new boots.
www.z1enterprises.com/motorcycles/Kawasa...ies/spark-plugs.html
spark plug boots 20 Jul 2021 14:46 #852142
  • TexasKZ
  • TexasKZ's Avatar
  • Away
(DANG, Mikaw is fast!!)
Here is the 3 Ohm choice.
www.z1enterprises.com/dyna-dual-output-3...%2Fall-models%2F1976
spark plug boots 20 Jul 2021 14:48 #852143
  • Mikaw
  • Mikaw's Avatar
Just happen to be at the place at the right time. Never get that lucky when it come to critical parts I need.
spark plug boots 20 Jul 2021 16:16 #852151
  • motoaddict
Perfect, Think I will just get new boots and try to stretch the wires a bit. So are the factory boots a resistor type?
1976 KZ900
spark plug boots 20 Jul 2021 16:35 #852156
  • Mikaw
  • Mikaw's Avatar
Yes I think about 5,000 ohms
spark plug boots 20 Jul 2021 17:13 #852160
  • TexasKZ
  • TexasKZ's Avatar
  • Away
If you are using resistor plugs, the resistor boots are not needed and vice versa.
spark plug boots 21 Jul 2021 09:28 #852198
  • Mikaw
  • Mikaw's Avatar
Just for S&G I checked the Kz1000 FSM and the in spec ohms range is different. 3.2~4.8 ohs on the primary.
spark plug boots 21 Jul 2021 11:08 #852200
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Well, ok.
You can choose from 1.5 to 4.
www.z1enterprises.com/motorcycles/Kawasa.../ignition-coils.html
spark plug boots 21 Jul 2021 16:50 #852226
  • motoaddict
"If you are using resistor plugs, the resistor boots are not needed and vice versa."
So I ended up dissecting the old boot and found only the hooked spring inside. Ended up cleaning it up, piercing the jacket in a new spot and pushing it back in to the boot. Good as new. So was this supposed to be a resistor boot? Should I get a set of resistor plugs instead? I tried to look up pictures of the original boots and these do not look like they are from kawasaki.
1976 KZ900
spark plug boots 21 Jul 2021 18:33 #852234
  • TexasKZ
  • TexasKZ's Avatar
  • Away
Honestly, that looks like a chainsaw or leaf blower plug boot. You do not actually need any resistors at all as long as you do not mind causing interference with nearby AM radios.
  • Page:
  • 1
  • 2
