Z1 Color Wiring Diagram? 13 Jun 2021 07:27 #850107
  • Robb2018
  • Robb2018's Avatar Topic Author
  • 76 KZ900 73 Z1 A
  • Thank you received: 29
Anyone have a link?
KZ900; Z1
Z1 Color Wiring Diagram? 13 Jun 2021 08:18 #850111
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 366
Here is one I have access to.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: Robb2018
Z1 Color Wiring Diagram? 13 Jun 2021 08:39 #850112
  • Robb2018
  • 76 KZ900 73 Z1 A
Thanks GD.  Here's the thing, I ordered new turn signals from Z1 Parts.  They sent me two sets, a two wire and a single wire.  The diagrams shows both front and back using two wire.  I shouldn't have to be running an extra ground wire, not sure why they sent two different sets.  Trying to figure out which will be easier, returning these and waiting another two weeks or working with the 1 wire set.
KZ900; Z1
Z1 Color Wiring Diagram? 13 Jun 2021 09:04 #850113
  • 73z1
  • 73z1's Avatar
  • Thank you received: 103
Original z1 turn signals use one wire through the stem and ground wire under stem nut.
The 2 wire from z1parts has tail light and turn light (not original).
Z1 Color Wiring Diagram? 13 Jun 2021 09:25 #850115
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1849
The Z1 and Kz900’s had no running lights in the front. Turn signals only, single element bulb. The rear tail/brake light has a dual element bulb, brake and running light. Just like the front the rear turn signals are single element bulbs, turn signal only, no running light. The correct turn signal NOS is still available. About $70.00 each. They are one wire and ground is through the stem. A black/yellow wire with a brass ring connector on one end and a 2.5 mm bullet connector on the other.
www.partzilla.com/product/kawasaki/23040...5755a43975a36efa02e6
www.partzilla.com/product/kawasaki/26011...5755a43975a36efa02e6
EDIT, It may be a 4mm male bullet on the end of the ground wire, memory vague.
Last edit: by Mikaw.
Z1 Color Wiring Diagram? 13 Jun 2021 09:29 #850116
  • Mikaw
  • Mikaw's Avatar
I was never able to find stems in good enough condition. And I didn’t find any NOS. I had my stems replated.
Z1 Color Wiring Diagram? 13 Jun 2021 09:34 #850117
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 351
look inside the bulb sockets to see which one you have.
A single terminal 1156
or a dual terminal 1157.
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Z1 Color Wiring Diagram? 13 Jun 2021 09:35 #850118
  • Mikaw
  • Mikaw's Avatar
No eBay APP ID and/or Cert ID defined in Kunena configurationThis was the closest aftermarket I could find.
Z1 Color Wiring Diagram? 13 Jun 2021 09:41 #850119
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1021
I believe the LTD version (with front turn signals on the bars) had running lights on the front.  I know mine does (1980) but not sure of other years.
I buy the covers through Partzilla.  I've only had baskets and stems replated, and have a few gathering dust waiting for their turn.
Z1 Color Wiring Diagram? 13 Jun 2021 09:47 #850120
  • Mikaw
  • Mikaw's Avatar
HRM your correct. The 1976 Kz900’s LTD had turn/running lights. They were mounted on the Handlebars. Thank You
Z1 Color Wiring Diagram? 13 Jun 2021 09:59 #850121
  • Mikaw
  • Mikaw's Avatar
Z1 Color Wiring Diagram? 13 Jun 2021 10:38 #850124
  • Robb2018
  • 76 KZ900 73 Z1 A
I've got a black and white diagram in both my factory manual and my Clymer.  The Clymer is most accurate because it specifies 73 and 74 Z1 but it's black and white.  I'm starting out from an electrically challenged position here and want to make it as easy as I can on myself.
KZ900; Z1
