  • Page:
  • 1
Show me whats under your covers! 78 kz650 SR 18 Apr 2021 19:18 #847007
  • xstreamcanadian
  • xstreamcanadian's Avatar Topic Author
  • Thank you received: 4
Im trying to re route as  close to original as I can, after fixing my harness up, and splitting it all apart. Im also trying to figure out what goes where under the side covers and under the seat. fuse box, tail light outage relay and all kinds of other stuff... I have the ignitor and flasher relays etc sorted.... i think. would just be great to have a visual to go by. Also trying to figure out the hinge system for the seat.
thank you
Show me whats under your covers! 78 kz650 SR 19 Apr 2021 08:59 #847029
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
I don't have a photo, but you can check partzilla to see what sort of electro brackets you should have.
The drawings are usually oriented how stuff should be mounted on the motorcycle.
For the 650-D1 >> battery case & chassis electrical diagrams:
Bracket #16 is probably mounted on the RH side of the battery box & either #17 or #25 should be fitted to it.
Also, there should be an oblong grommet for the main electro bracket, so some of the wiring would be routed thru that orifice.
ps: stock, the D1 wouldn't have had an igniter.
The following user(s) said Thank You: xstreamcanadian
Last edit: by martin_csr.
Show me whats under your covers! 78 kz650 SR 24 Apr 2021 19:36 #847384
  • xstreamcanadian
thanks ill have a look
Show me whats under your covers! 78 kz650 SR 24 Apr 2021 20:39 #847387
  • Thank you received: 2828
Here's what under the covers on my 1977 KZ650-C1.  Ed
  • Page:
  • 1
