  • Page:
  • 1
  • 2
Koso RX2N+ GP Style - Switch bracket mounting 12 Apr 2021 01:19 #846561
  • gordone
  • gordone's Avatar Topic Author
  • Thank you received: 67
Hi,
I`m looking into install Koso RX2N+ GP Style with sensor on the rear wheel.
There should be straight forward job to drill a whole in the brake calipet bracket and make some threads for a bolt to the sensor bracket?
Shall the sensor pickup the wholes in the brake disc or the bolts holding the brake disc ?
Project:
Koso RX2N+ GP Style - Switch bracket mounting 12 Apr 2021 04:37 #846565
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
Hi,
Yes, if your rotor bolts are magnetizable, (some stainless bolts did not), you can use the rotor bolts.
Koso RX2N+ GP Style - Switch bracket mounting 12 Apr 2021 14:28 #846596
  • gordone
Thank you, will check it :)
it’s not a problem that it gets two many pulses per rotation? When driving fast, so the pulses have to high hz so the speedo loose pulses?
I see I have more bolts then you?
Project:
Koso RX2N+ GP Style - Switch bracket mounting 12 Apr 2021 17:26 #846601
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
So more bolts per wheel rev, so more accurate the speed readings!
Koso RX2N+ GP Style - Switch bracket mounting 13 Apr 2021 01:00 #846612
  • gordone
Agree, but the pulse "train" will be much faster also... just wondering if the input is fast enoudh to detect it.
If the scan time on the input is lower then the pulsing will it loose pulses and I will not get correct reading...
Project:
Koso RX2N+ GP Style - Switch bracket mounting 13 Apr 2021 02:21 #846614
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
The pulse "train" set up has the same function as your ignition pic-ups, The eletronic igniter can handle a lot more than + 10000 rpm = + 20000 impulses per min.
Last edit: by Scirocco.
Koso RX2N+ GP Style - Switch bracket mounting 13 Apr 2021 05:22 #846617
  • gordone
Perfect, quite high sampling rate then.
Think I will go for these speedo  :)
Project:
Koso RX2N+ GP Style - Switch bracket mounting 17 Apr 2021 01:27 #846913
  • gordone
I’m consider a different model from Koso (maybe better match when it comes to style for my bike).
KOSO Digital DL-03SR
I can see it follow magnets for the sensor, does that mean I need to use them?
www.scooter-center.com/en/speedometer-ta...-64mm-black-bb642w20
Project:
Koso RX2N+ GP Style - Switch bracket mounting 17 Apr 2021 01:44 #846914
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Yes, you need to use the magnets. The KOSO Digital DL-03SR has a passive sensor.
Koso RX2N+ GP Style - Switch bracket mounting 17 Apr 2021 15:17 #846948
  • gordone
Thank you, do you know if I can install a active sensor to the speedo? Same sensors as you have example?
I guess using magnet is something I should try to avoid...?
Project:
Koso RX2N+ GP Style - Switch bracket mounting 17 Apr 2021 15:59 #846949
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Which sensor (passive/active) you get is dependent of the type of tacho/speedo you order. The newer, quite more expencive KOSO tachs have an active sensor with a blue flashing impulse indicator LED on top.
Koso RX2N+ GP Style - Switch bracket mounting 18 Apr 2021 04:49 #846966
  • gordone
I understand, maybe it’s posdible to have a converter from active to passive...
active sensor - cable - converter to passive - cable - speedo input.
jeje I will look further to see if I find a speedo with active sensor and a look I like...,
Project:
  • Page:
  • 1
  • 2
