Help with Kz750 charging issues 17 Mar 2021 08:08 #845064
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 353
It all seems wired correctly.
I'm just really curious about voltage drops along all the reg/rec lines.
When you have a chance, do the tests and report back.
81-KZ440-D2.
LIC, NY
Help with Kz750 charging issues 23 Mar 2021 18:35 #845407
  • JohnLuke
  • JohnLuke's Avatar Topic Author
  • 1982 KZ750N Spectre
  • Thank you received: 5
I haven’t done to test yet. But I did rewire the three yellow wires. I did to to make sure nothing was amiss with the bullet connectors. And for some reason I had two sets of them along the yellow wires. Didn’t make sense. After rewiring it it idles (my idle is pretty low normally). Around 13v. So there is improvements. And I was able to rev it a bit up to 13.5v or so. But I didn’t rev it high enough because I don’t want my neighbors to hate me. So like I said. Improvement. But not right. Any more ideas? Should I go ahead and do that test?
Help with Kz750 charging issues 23 Mar 2021 19:05 #845410
  • F64
  • F64's Avatar
  • 81-KZ440D2
Testing would help.
You could keep changing parts and get lucky, but that gets expensive with time and money.
81-KZ440-D2.
LIC, NY
Help with Kz750 charging issues 23 Mar 2021 19:44 #845411
  • JohnLuke
I’ll test it hopefully sometime this weekend and try my best to document the results.
The following user(s) said Thank You: F64
Last edit: by JohnLuke.
