  • Page:
  • 1
  • 2
Is all B7ES plugs the same? 24 Dec 2020 19:24 #840538
  • katit
  • katit's Avatar Topic Author
  • Thank you received: 48
Got a set from ebay without thinking twice, b7es - 11
They don't have thread on ends, so I can't put caps on. Is that a wrong spark plug or what? Is this -11 means its' got "blob" instead of threads?
PS. I did think I can unscrew top to reveal threaded smaller tip but no. I pulled whole thing (unscrewed loktite from within ceramic) It looks like top contact is one piece..
Last edit: by katit.
Is all B7ES plugs the same? 24 Dec 2020 19:37 #840540
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2672
Yeah, they make both types (or at least used to); threaded end and unthreaded.
Is all B7ES plugs the same? 24 Dec 2020 19:41 #840541
  • katit
Thanks! Even more sux, don’t see any with threaded ends on bay.
Is all B7ES plugs the same? 24 Dec 2020 19:49 #840543
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1853
Look for B7ES/1111 they will be removable top
Be careful ordering of evilbay. NGK has been known to be faked. Your better off ordering from your local auto parts
The following user(s) said Thank You: katit
Last edit: by Mikaw.
Is all B7ES plugs the same? 24 Dec 2020 20:06 #840544
  • katit
Is b7es just different number for 1111? When I search autozone for b7es they show 1111
Many places show numbers together
Is 1111 ngk is what I need then?
Is all B7ES plugs the same? 24 Dec 2020 20:46 #840547
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 366
No eBay APP ID and/or Cert ID defined in Kunena configurationI would suggest Denso plugs - 3039
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Is all B7ES plugs the same? 24 Dec 2020 20:47 #840548
  • Mikaw
  • Mikaw's Avatar
1111 is the item/part number. B7ES is the plug number I think. I ordered some and I know 1111 was on the item/part number.
Is all B7ES plugs the same? 24 Dec 2020 23:39 #840550
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2051
I buy NGK plugs from a local NAPA store, that way I am confident I a will not get fakes, and can easily return them if there is a problem.
Is all B7ES plugs the same? 25 Dec 2020 21:18 #840587
  • Mc Tavish
  • Mc Tavish's Avatar
  • Thank you received: 35
The 11 refers to the gap, ie, 11 =1.1mm gap.
1978 z650C
Is all B7ES plugs the same? 26 Dec 2020 09:22 #840602
  • Mikaw
  • Mikaw's Avatar
Mc Tavish wrote: The 11 refers to the gap, ie, 11 =1.1mm gap.
Thanks, that makes sense because the B8ES have a part number of 2411
Is all B7ES plugs the same? 26 Dec 2020 13:55 #840609
  • katit
Sarcasm?
Is all B7ES plugs the same? 26 Dec 2020 14:59 #840610
  • Mikaw
  • Mikaw's Avatar
Sarcasm?
Not at all.
  • Page:
  • 1
  • 2
