  • Page:
  • 1
  • 2
Yuasa battery 26 Nov 2020 04:34 #838956
  • gordone
  • gordone's Avatar Topic Author
  • Thank you received: 67
Last year I have used cheap battery, but when the bike have stand for some wheel example its to weak to start the motor sometimes...
I want to have quality battery and not be worried about the start clutch to wear out faster then it needs to....
Yuasa YTX20H-BS
www.yuasabatteries.com/battery/ytx20h-bs/
Is these a good choice ?
Project:
Yuasa battery 26 Nov 2020 04:49 #838959
  • 73z1
  • 73z1's Avatar
  • Thank you received: 103
Yuasa makes good batteries.
Yuasa battery 26 Nov 2020 05:02 #838960
  • gordone
73z1 wrote: Yuasa makes good batteries.
18AH is fine also, I see the service manual say 12AH orginal.
I will try to find a without acid, so I can fill it my self, to best quality (if it has been stored for a while at warehouse).
Project:
Yuasa battery 26 Nov 2020 06:31 #838963
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
Is there a power source nearby so that a charger can be connected when the motorcycle is not ridden.
Er det en strømkilde i nærheten slik at en lader kan kobles til når motorsykkelen ikke kjøres.
My current battery is a Scorpion AGM & it is now 3 yrs + 3 mos. old. I keep a smart charger connected
whenever the motorcycle is parked in the garage. Ctek US 0.8 smart charger (Sweden).
Mitt nåværende batteri er en Scorpion-generalforsamling, og det er nå 3 år og 3 måneder gammelt.
Jeg holder en smart lader tilkoblet når motorsykkelen står i garasjen. Ctek US 0,8 smartlader (Sverige).
Last edit: by martin_csr.
Yuasa battery 26 Nov 2020 07:24 #838969
  • scubaanders
  • scubaanders's Avatar
  • Thank you received: 233
Yuasa is top notch and you should bu it dry.
Never did I expect that Martin is fluent in Norwegian :) :cheer:
/Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Yuasa battery 26 Nov 2020 07:51 #838974
  • martin_csr
Yes, I'm fluent. in google translate. :lol:
The following user(s) said Thank You: BCScott
Yuasa battery 26 Nov 2020 08:09 #838976
  • Thank you received: 2829
I've been using Yuasa batteries in my 1977 KZ650 since it was new and they work great. One question though - you show a Yuasa YTX20H-BS battery, but my 1977 KZ650 has always used a Yuasa YB10L-A2 battery. Make sure the battery you list is the correct one for your bike because I believe the one you list is the wrong size for the KZ650. The Yuasa YB10L-A2 battery is 5 5⁄16 in. x 3 9⁄16 in. x 5 3⁄4 in., but the Yuasa YTX20H-BS battery is 6 7⁄8 in. x 3 7⁄16 in. x 6 1⁄8 in. Ed
Yuasa battery 26 Nov 2020 08:40 #838978
  • gordone
650ed wrote: I've been using Yuasa batteries in my 1977 KZ650 since it was new and they work great. One question though - you show a Yuasa YTX20H-BS battery, but my 1977 KZ650 has always used a Yuasa YB10L-A2 battery. Make sure the battery you list is the correct one for your bike because I believe the one you list is the wrong size for the KZ650. The Yuasa YB10L-A2 battery is 5 5⁄16 in. x 3 9⁄16 in. x 5 3⁄4 in., but the Yuasa YTX20H-BS battery is 6 7⁄8 in. x 3 7⁄16 in. x 6 1⁄8 in. Ed
I will double check the measurements to make sure it fits.
I shall try to get highest possible of Ah, as long as it physical fits ?
Project:
Yuasa battery 26 Nov 2020 08:43 #838979
  • gordone
martin_csr wrote: Is there a power source nearby so that a charger can be connected when the motorcycle is not ridden.
haha funny :)
Shall we start writting a random language ? :)
Project:
Yuasa battery 26 Nov 2020 09:10 #838981
  • gordone
Since you all are so good in Norwegian :)
www.biltema.no/bil---mc/bilbatterier/bat...-12-v-8-a-2000040408
Minimum voltag - 2 volt
Will I`m able to charge the battery from 0v with these charger ?
Project:
Yuasa battery 26 Nov 2020 10:27 #838992
  • gordone
I will go for a CTEK inteligent charger, as Martin has, det swedish one :)
Project:
Yuasa battery 26 Nov 2020 11:37 #838995
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 506
For normal 12v lead-acid batteries, once it's discharged to 11 volts all the energy has been removed from the battery. It's empty. If it continues to be discharged, it starts to damage the battery.
A battery at 2V is probably permanently damaged. Even if it recovers it will probably have lost capacity and performance.
A battery at 0v is certainly permanently damaged.
My dad's '74 Z1
'00 ZRX1100
  • Page:
  • 1
  • 2
