Dyna S Ignition Users - Feedback 18 Sep 2020 16:57 #835321
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
  • Thank you received: 23
Hpw many here noticed that DynaS sold new about 3-6 years ago had much higher failure rate, It seems Dyna has since fixed the problem, but it is hard to have confidence in the new ones. How many miles have guys got on ones bought in the last six years? I only trust the really old ones now. These old ones seem like they will last forever.
Dyna S Ignition Users - Feedback 18 Sep 2020 17:18 #835323
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1467
seanbarney41 wrote: How many here noticed that Dyna S sold new about 3-6 years ago had much higher failure rate, It seems Dyna has since fixed the problem, but it is hard to have confidence in the new ones. How many miles have guys got on ones bought in the last six years? I only trust the really old ones now. These old ones seem like they will last forever.
Got a new one on the Alloy Cafe i built 5 years ago which i use most days with no problems so far and running another two for 20 and 11 years respectively trouble free.
With the volume they produce there's always going to be a few that fail and you will always hear of complaints of those that go wrong but hardly ever of the countless others that work as they should except in threads like this..
Dyna S Ignition Users - Feedback 18 Sep 2020 18:51 #835325
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1858
DOHC, exactly the reason Im interested in the rev limiter. Not only have I found neutral between 1 and 2, but once I was lucky enough to find that hidden natural between 4 and 5, embracing but so far lucky no damage. If a few buck will save me from a bent valve or beat up piston its worth it.
Dyna S Ignition Users - Feedback 18 Sep 2020 20:19 #835328
  • seanbarney41
Well, I think Dyna did have a real problem for a few years there. I personally witnessed three different units fail that were purchased during this rough time period...2 for Harley sportster and one on my kz650, in addition to several internet reports. But I have 3 very old (at least 10 years) units that just never miss, 2 for Kawasaki and one for Honda cb750 (not sure but think cb750 and Kawasaki might use the same unit?)
Dyna S Ignition Users - Feedback 19 Sep 2020 05:12 #835336
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
I have 3 Dyna S setups. One is about 5 years old, the second is about 3 and the third is new this year. No issues other than with the hot wire connector.
Dyna S Ignition Users - Feedback 19 Sep 2020 16:08 #835378
  • VTEC
  • VTEC's Avatar
  • Thank you received: 80
Three things I've learned using the Dyna 2000. One is you can't time it with a light accurately. The mark jumps all over the place. Dyna support says it's normal. Static time only.
Another is the instructions state use timing curve #5 (full advance at 6500 rpm) for a high compression 2 valve engine, but use #4 (full advance at 3500 rpm) for stock 2 valve even if you're running 10.5:1 pistons. Much better performance for street riding. Also confirmed by Dyna support.
Last but not least, had an intermittent no spark on start up condition that kicked my ass. Tried everything including a relay for 12 volts direct to coils and module. Finally ended up buying a new module to fix the problem. The problem was there from day one with the system fresh out of the box.
KZ1000-K2
ZRX1100
XR400R
Last edit: by VTEC.
Dyna S Ignition Users - Feedback 19 Sep 2020 16:19 #835381
  • Mikaw
  • Mikaw's Avatar
VTEC wrote: Another is the instructions state use timing curve #5 (full advance at 6500 rpm) for a high compression 2 valve engine, but use #4 (full advance at 3500 rpm) for stock 2 valve even if you're running 10.5:1 pistons. Much better performance for street riding. Also confirmed by Dyna support.
The lower rpm advanced makes sense. The factory full advance is about 2450 if I recall correct.
Dyna S Ignition Users - Feedback 19 Sep 2020 16:44 #835384
  • VTEC
  • VTEC's Avatar
Maybe they saw an advantage in a drag race, and/or they were talking higher compression than 10.5:1. But for us street people, use #4.
KZ1000-K2
ZRX1100
XR400R
