  • Page:
  • 1
  • 2
Speedometer Odometer Trip Whitening 10 Sep 2020 05:01 #834714
  • asphalt900
  • asphalt900's Avatar Topic Author
  • Thank you received: 166
For Kaylinator and his KZ1000 and whoever else? This is what i do to whiten the registers for trip and mileage. A bit involved but once the needle and face are off..... I remove the Mileage register with a "custom" vice grip. The metal is folded over the shaft on the mileage register. One side requires opening quite a bit, the other just enough to relieve tension so the shaft can be slid out. A little brass e-clip has to be removed to slide the wheels/plates and gears off. Pay attention as to how they are removed to aid reassembly. Use a little baggie and pour in the Peroxide and whatever wheels need whitening. Let it sit in the sun for as long as it takes, check every couple hours. Wipe, don't rub, numbers won't be affected.
The following user(s) said Thank You: loudhvx, ThatGPzGuy, TexasKZ, martin_csr
Speedometer Odometer Trip Whitening 10 Sep 2020 05:23 #834715
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2050
Is that hydrogen peroxide?
Speedometer Odometer Trip Whitening 10 Sep 2020 07:42 #834725
  • asphalt900
Yes. It comes in different concentrations. It's just some sort of hair coloring/bleaching formula. I'm sure there is a different product that does the same but this seems to work just fine. Ran across it on a video from a gent that was whitening an old bathroom fart fan cover, ha.
Speedometer Odometer Trip Whitening 10 Sep 2020 08:12 #834730
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1849
Different but similar, would that product work to whiten the plastic master cylinder reservoir ?
Speedometer Odometer Trip Whitening 10 Sep 2020 08:27 #834733
  • asphalt900
As a matter of fact...YES. As long as they are not too brown and crumbling. I've several of the rear KZ reservoir's.
Speedometer Odometer Trip Whitening 10 Sep 2020 08:36 #834738
  • asphalt900
Here is an example. This one was pretty piss-poor but just faced the better side out. Note the bad shape plastic in one photo, it was really brown before.
Speedometer Odometer Trip Whitening 10 Sep 2020 09:16 #834745
  • Mikaw
  • Mikaw's Avatar
asphalt900 wrote: As a matter of fact...YES. As long as they are not too brown and crumbling. I've several of the rear KZ reservoir's.
So what’s the process Mr Miyagi, wax on wax off? Or apply and leave it on then remove.?
Speedometer Odometer Trip Whitening 10 Sep 2020 10:11 #834747
  • asphalt900
Grasshopper, Mr. Miyagi suggests Baggie. Fill it and forget it, info commercial (sounds like). We must all be out of work today, raining here,
The following user(s) said Thank You: SWest, Mikaw, calum
Speedometer Odometer Trip Whitening 10 Sep 2020 13:09 #834762
  • TexasKZ
  • TexasKZ's Avatar
asphalt900 wrote: Yes. It comes in different concentrations. It's just some sort of hair coloring/bleaching formula. I'm sure there is a different product that does the same but this seems to work just fine. Ran across it on a video from a gent that was whitening an old bathroom fart fan cover, ha.
Plain hydrogen peroxide is stoooopid cheap. Clear and runny as water. I wonder if there are other ingredients in that hair goo that are important to the process.
Speedometer Odometer Trip Whitening 11 Sep 2020 01:56 #834790
  • Kaylinator
  • Kaylinator's Avatar
  • Thank you received: 74
Thanks Asphalt!
Can't find that Salon Care anywhere, and the old lady has never even heard of it. I'll have to see what other peroxide product I can find and cross my fingers.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
Speedometer Odometer Trip Whitening 11 Sep 2020 02:19 #834791
  • asphalt900
Just type Salon Care 40 into an ebay search, bunch of them for sale. Mine is only a 4oz. bottle and it's lasted a long time. Texas, i don't know what else is in it, i know it doesn't taste like chicken?
Speedometer Odometer Trip Whitening 11 Sep 2020 11:32 #834808
  • TexasKZ
  • TexasKZ's Avatar
:lol:
Chicken doesn't taste like chicken most of the time. Have you ever tried straight hydrogen peroxide? Don't have to GTS.
  • Page:
  • 1
  • 2
