Spark Plug Gap 07 Jul 2020 13:45 #830041
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 335
SETI is fun..
Even better is bluetooth. My ignition system totally jammed my bluetooth connection with my m-unit.
I forgot to try my cell phone data connection as I was so miffed.
So if your phone reception is something awful....Try shutting off your bike and trying the phone again.
I was also running solid core wires with rajahs. That about as bad as you can get.
I really got tired of the electrocution though.
Luis
Sorry about the distractions.
Your NGK B6ES are fine.
Your link is broken so that may be why no one has commented on it.
www.ngk.com/product.aspx?zpid=9229
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Spark Plug Gap 14 Jul 2020 09:14 #830648
  • luisazmz
  • luisazmz's Avatar Topic Author
  • Thank you received: 0
Excuse the few days that've gone by, my soldering iron decided to stop working the day the relay arrived so I had to wait another few days for the new one. I finally got around to installing it yesterday. I set the spark plug gap to the appropriate spacing (0.7mm) and still nothing, I did notice though the bike does run if I set it to 0.35mm which before it wouldn't at all. When it started up it sounded much different, there weren't as many misfires as before. The voltage now on the coils is the same as the battery as oppose to before it was 1 volt lower. The sparks look much brighter than before, but still can't get it to run with the proper gap. What else could be affecting it? Thank you guys for the help.
Spark Plug Gap 14 Jul 2020 09:41 #830651
  • F64
  • F64's Avatar
  • 81-KZ440D2
what is you points gap set to?
81-KZ440-D2.
LIC, NY
Spark Plug Gap 14 Jul 2020 10:28 #830656
  • luisazmz
Set to .35mm. The points are clean and they fully touch and separate when they open and close.
Spark Plug Gap 14 Jul 2020 18:41 #830683
  • F64
  • F64's Avatar
  • 81-KZ440D2
I feel bad. You told me your point gap 3 different times .35mm and i still asked what is your gap set to.
Put your meter to DC V
Ignition on/engine off
Black meter probe on the negative battery post.
Red meter probe on hex nut of spark plug
If your voltage is higher than .5 V then you have a bad ground at your spark plug
Turn off your ignition.
Disconnect both spark plug wires.
Measure the resistance with one probe in one spark plug wire and the other probe in the other spark plug wire.
Note resistance
Drop the point gap to .30mm.
It'll give the coils a bit more charge time.
Recheck your timing after your point gap change.
Which coil did you buy?
Are your points new?
81-KZ440-D2.
LIC, NY
Spark Plug Gap 15 Jul 2020 19:56 #830776
  • F64
  • F64's Avatar
  • 81-KZ440D2
is your condenser new?
Are your points sparking?
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Spark Plug Gap 15 Jul 2020 20:42 #830778
  • Thank you received: 2828
F64 wrote: ..................
Also, are they genuine Kawasaki parts or aftermarket? Some aftermarket stuff isn't really up to Kawasaki specs. Ed
Last edit: by 650ed.
Spark Plug Gap 16 Jul 2020 14:39 #830827
  • F64
  • F64's Avatar
  • 81-KZ440D2
Luis,
Your problem seems a lot like gavroyer's problem.
Check and see if your points are sparking when running.
www.kzrider.com/forum/forum-index/4-elec...-kz440a1-with-points
You may have a bad condenser.
See if you can grab a NOS Kawasaki condenser.
#21013-034
www.google.com/search?client=firefox-b-1-e&q=21013-034
81-KZ440-D2.
LIC, NY
Last edit: by F64.
Spark Plug Gap 17 Jul 2020 09:27 #830872
  • luisazmz
I set the points gap to .3 and it helped a tad, it's running somewhat smoother now and the idle is much lower before it was at 3k now it's close to 1.8 without adjusting the carbs, just with that .05 difference in the points. I'm currently running the spark plugs at .35mm spacing as I mentioned before.
The voltage between the battery and the spark plug is very close to 0V. The resistance in the secondary winding is about 14 kΩ so it's within the specs of the manual.
The condenser is brand new, I changed it about a month ago because I thought it could be that. The points began sparking when I closed them the extra .05mm to set them at .3mm.
I bought the points and condenser off ebay, it said they were oem.
Points & Condenser Link
Last edit: by luisazmz. Reason: added link
Spark Plug Gap 17 Jul 2020 10:39 #830876
  • gavroyer
  • gavroyer's Avatar
  • Thank you received: 13
That's not a Kawasaki condenser. It might still be fine, but that could be a problem. I bought a brand new condenser that failed within a couple weeks of installation.
1980 KZ440-A1 LTD
Spark Plug Gap 17 Jul 2020 10:54 #830878
  • F64
  • F64's Avatar
  • 81-KZ440D2
I think your condenser may be the problem.
The brand of those parts is JIS not kawasaki.
Do you have your old condenser and was it the original part?
81-KZ440-D2.
LIC, NY
Spark Plug Gap 17 Jul 2020 12:23 #830885
  • luisazmz
The bike had the original one when I got it, it was incredible how much it would backfire, I swapped it out for this one and the problem disappeared. I went ahead and purchased a Kawasaki condenser to see if maybe it will do it. Hopefully it's that. The wait is on :lol:
