  • Page:
  • 1
1976 KZ400 No Spark 05 Jan 2017 14:33 #751479
  • CHARGER
  • CHARGER's Avatar Topic Author
  • Thank you received: 0
Hi Guy's trying to get an old KZ400 to run before a strip down and restore and I have no spark
Firstly the coil seemed faulty as when I did an Ohms test between both plug leads I got no reading, Purchased a replacement coil and installed but still same problem, new coil tests fine on both circuits with multimeter. So far I have checked the below
1. 12v Power to Red Yellow wire going to coil checked OK
2. Points, cleaned set and tested OK, "Points haven't been replaced by me but they look in good condition" and test fine with test light
Is it possible a faulty condenser can cause no spark? that's about all I am left with, I have ordered one but as I understood a condenser is just basically a capacitor to absorb high voltage so your points don't burn out too quick can this cause no spark if faulty?
Cheers in advance
1976 KZ400
1981 KE175
1976 KZ400 No Spark 05 Jan 2017 15:45 #751488
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2065
Have you load tested the battery? Only 12v at the coil is a bit weak. A good battery, good wires and clean connections should provide around 13v at the coil.
Also check the battery ground cable to be sure it is free from corrosion and that it has a very clean connection to the crankcase or frame.
The kill switch is set to RUN, right?
1976 KZ400 No Spark 05 Jan 2017 15:51 #751489
  • CHARGER
-Battery fine, i'm running from jumper cables from a car battery fully charged, headlight bright, would think that means my ground is good too....
-Kill switch functioning correct, if it was off I would not have power to the Red Yellow wire
-Have tested blue wire at coil with test light it flashes when motor turns so points seem fine just getting no juice out of plug leads from coil
Condenser seems to be the only thing left but I thought that only absorbed high voltage to save points burning out prematurely
1976 KZ400
1981 KE175
1976 KZ400 No Spark 05 Jan 2017 16:12 #751494
  • CHARGER
Just learnt how to test plug caps, pretty sure this is my issue.....
Will report back
1976 KZ400
1981 KE175
1976 KZ400 No Spark 05 Jan 2017 16:39 #751498
  • TexasKZ
  • TexasKZ's Avatar
Please be sure that the car is not running when you try this. Its alternator output will fry your bike's electrical system .
1976 KZ400 No Spark 05 Jan 2017 17:05 #751501
  • CHARGER
Yes not in car just a spare car battery.
Alright so it's my resistor caps, guessing the high resistance burnt out the original coil too.
Anyone got an NGK Replacement Part Number or equivalent I can use and is the spec 5k ohms?
1976 KZ400
1981 KE175
1976 KZ400 No Spark 05 Jan 2017 18:08 #751507
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
I wouldn't worry about cap resistance. If you just want to get it running before you tear it down to make it pretty.
Just use any plug wires and coil that works . You can change it out later.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
1976 KZ400 No Spark 05 Jan 2017 20:41 #751517
  • TexasKZ
  • TexasKZ's Avatar
Like Nebr_Rex said, any ole cap will do. If you are worried about creating rf interferance once the bike is running, you can use resistor plugs OR resistor caps OR resistor wires, but never more than one of them. You can also run without any of them
1976 KZ400 No Spark 05 Jan 2017 23:42 #751520
  • CHARGER
Had some spare caps off an old CB400T, as soon as I put them on I got spark, tried the old cap again zero spark :blink:
Anyways have ordered some NGK LB05F to use eventually
1976 KZ400
1981 KE175
1976 KZ400 No Spark 06 Jan 2017 03:32 #751523
  • Thank you received: 2098
Defective plug wire?
Ohm-checked secondary loop (cap to cap)?
A non-conductive (defective) plug cap is one of the many possibilities whereby a break is created in the secondary loop which prevents plug spark.
Properly functioning secondary loop with
both spark plugs simultaneously firing:
Good Fortune! :)
Last edit: by Patton.
1976 KZ400 No Spark 02 Jun 2021 16:51 #849497
  • Bigryde55
  • Bigryde55's Avatar
Well hey I got a problem with a barn find kz400 S  .I get the bike it was locked up .So I  get in piston and rings  put it together something is hitting I find out valves are stuck .So I fix that problem I get it loose .then I find out starter button isn't working or on and off .So I cut wires and get starter and on switch working .My key switch seems to be working .I find out I have no spark to plugs .so I check wires and figure maybe coil is bad so I buy cool ,I still have no spark .I trace a plug coming out of magneto and find one side is hot other side of plug is dead .Soni straight hook up wires and take plug away .much to my amazement  I find  connection dead I'm puzzled .So I unhook wire red I think going into light blue and it's live again .I connect them back and it deadens both wires .what is going on here.i tested coil got two wires to that there hot .but I hook rest light to spark plugs wires I got nothing .Anybody know why I don't have fire to plugs help me out here thanks
1976 KZ400 No Spark 02 Jun 2021 17:25 #849501
  • TexasKZ
  • TexasKZ's Avatar
Stop.
Before you randomly chop up the harness anymore, put things back where they belong. The factory service manual has specific tests to diagnose such problems. Cutting wires and bypassing parts of the system just creates the possibility of more problems and will make diagnosis more difficult.
www.kzrider.com/modules/ServiceManuals/7...chablefullmanual.pdf
  • Page:
  • 1
