Jerka wrote:
Okay, so let me get this straight...every time I get off the bike I need to switch the fueltap to off? Is that on the petcock? Every night or every time I get off the bike?
If I go with the Uni filters, do I need to rejet? If I do need to rejet, how do I know what size jets I need and where do I get them, also how much $ for new jets?
Sorry, I'm a total Noob, but things are starting to make more sense...if it's any consolation.
for your 400 you WILL have to rejet your carbs to run pods. for just a replacement filter in the stock box you dont have to. i would have a qualified person rejet your carbs if need be. wiredgeorge could answer some questions for you though. kz400jets can be found at
www.z1enterprises.com/catalog.aspx?pid=KZ400-D3-1976-CF0 not on the list but if you contact them they have access.
your petcock isnt vacuum and you dont have to turn the fuel off at every stop just over night.
down is on, up is reserve, and left is off.
if you start to run out of gas switch to res and get to the closest station.ive run out 1 time and even on the res i bareley made it.(about 2 miles from where it started puttin)
Post edited by: mykznme, at: 2006/08/17 16:28
