OK, so I think this is right. This is an old pic of the carbs in question, they were working fine back when this was taken, they now have alot less black on them.
I have drained the float bowls by loosening the hex nut at the bottom and fuel came out the drain hose. It does make some sense that a clear hose atached to this and then loosen the hex nut, with the petcock on ON with gas in the tank, would show a leve of the floats. My friend did similar with a section of hose to read gas in his 55 gallon drum gas tank on his pick-up.
If that is the vent hose is question, I can check that wednesday. I think, but my mind is a bit resinous still, I saw this running into the air box, just hanging there?
Post edited by: godsjester71, at: 2006/07/24 18:35
