ok, I'll try to stay on point for to your reply & questions....so, there are 2 types of piss gas from CRs I've experienced: 1) when the float completely sticks and gas pisses out of the 2 teeny upper vent holes on the back of the carb, literally shooting out almost to swingarm and 2) the carb fills with gas and gas pisses out of the bottom of the carb & air cleaner ......since I have removed & replaced the o-rings & needles, two times I have experienced the 2) type gas piss, and both times it was #3 carb (3rd carb in from left side, the one running richest) ......this is only happening at idle after I come back down from high Rs riding, and it stops as soon as I take off fast down the road ........gas tank, petcock filter, etc spotless, ultra clean .....I will be draining the bowls as you suggest, capturing the fuel and seeing if anything in fuel in bowls .....I'm also going to drop all 4 bowls and look across / measure float drops with bike level on center stand to see if they are all the same ......when I had the rack off for the o-ring & needle replace, interior of carbs were ultra clean.....yes, B7ES standard / factory rec plug, but I have had major top end work (2nd over pistons & rings, A P E valve guides & springs, GPZ 750 cams, etc) so I run colder plug, the iridium BR8EIX ......questions:
can the pilot air screws be adjusted complete in / down / closed ? what do they do ? what air do they control ?
all of my rubber pieces on all 4 choke plungers are hard as rocks, guessing I should replace all 4 ?
what jet having a speck of something in it would cause this at idle but then stop it once bike was flying down the road at high Rs ?
can the teeny vent holes on the carbs and their venting chambers be clogged ? (I plan to blast carb cleaner into & down them and then blow them out with compressed air)
lastly, I think I may send them off for this service:
