  • Page:
  • 1
Idle mixture screwdriver 13 Sep 2022 10:17 #873831
  • scubaanders
  • scubaanders's Avatar Topic Author
  • Thank you received: 233
Have you like me cursed all living and dead carburetor designers that placed the idle mixture screw on the underside of the carbs?Blessed are the guys at Mikuni that placed the screws on top, genius engineering that when into that.
Every now and then a friend shows up and ask if I can adjust their carbs, lately I was unlucky and a friend owning a CB750F -83 showed up and unfortunately, I agreed to help out. Little did I know about the Keihin VB42 carbs, what a pain. The floats cannot be adjusted, and they only come into styles, overflowing or much too low.
Anyhow trying to set the Idle mixture turned out to be a close to death experience, I had not tool except just a screwdriver bit to try to adjust the mixture. Definitely not the right tool for the job, so I made these if any of you need.
Whipped out a miniature screwdriver in Fusion 360
and printed them on my Creality Ender 3 Pro.
Fusion project and SLT files for 20 and 25 mm screwdrivers attached.
File Attachment:
File Name: Pilot jet ...iver.zip
File Size:129 KB
Brgds Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
The following user(s) said Thank You: Nessism, howardhb, Wookie58
Last edit: by scubaanders.
Idle mixture screwdriver 13 Sep 2022 10:47 #873832
  • kevski
  • kevski's Avatar
  • Thank you received: 154
Nice little screwdrivers, like you I had the same problem and I have small hands, I myself done something similar with the screwdriver tip in a sleeve so the whole thing covers the screw head stopping it sliding off, I shall dig it out and get a pic of it, on my little super four it's even harder  so I turned the screw heads so they were thinner and made some 1/4" long brass nuts and now use a 2 and 1/2inch long ratchet designed for those tiny screwdriver bits, sometimes you just have to think outside the box.
The following user(s) said Thank You: scubaanders
Idle mixture screwdriver 13 Sep 2022 12:26 #873837
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
  • Thank you received: 223
I use a small screw tip with a small piece of 1/4 inch fuel line stuck on so I can grab it.
Idle mixture screwdriver 13 Sep 2022 15:53 #873846
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1858
I guess I’m just old and dumb, I just burn the crap out of my hand a cus a lot. That mini flat blade screwdriver is cool
Last edit: by Mikaw.
Idle mixture screwdriver 13 Sep 2022 16:37 #873849
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 305
We use a Motion Pro geared 90° screwdriver. It comes with tips and the handle clicks in 1/8th turn increments.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Last edit: by Kelly E.
Idle mixture screwdriver 14 Sep 2022 04:43 #873868
  • kevski
  • kevski's Avatar
no chance with my little superfour.
Idle mixture screwdriver 14 Sep 2022 05:27 #873870
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 431
Dang-it, I neeeeed one of those!
Seems like a perfect subject to 3D-print, except of course the steel tube, main shaft and screw-driver bits (got loads of those in the bottom of my tool-box, for some reason !)
Maybe I should to draw helical bevel gears, for a smooth action... hmmmm
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
Last edit: by howardhb.
Idle mixture screwdriver 14 Sep 2022 08:23 #873876
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 656
Simple tool to make using radio controlled model car differential bevel gears.
Z1000J2 somewhat modified!
Last edit: by Warren3200gt.
Idle mixture screwdriver 14 Sep 2022 10:33 #873884
  • scubaanders
Darn and all of a sudden it turned in to one of those "got a have" moments.
Guess I am back in front of Confusion 360!
As a rod I have got some stainless tube, got to se if I will print the gears or use some pree made.
Brgds A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Idle mixture screwdriver 14 Sep 2022 13:50 #873890
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 369
Not mine but rather belonging to someone who does it for a profession Mike Nixon
motorcycleproject.com/text/tools01.html
motorcycleproject.com/text/tools02.html
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
Idle mixture screwdriver 15 Sep 2022 14:32 #873941
  • riturbo
  • riturbo's Avatar
  • Thank you received: 277
Heres mine
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Page:
  • 1
