Any Interest In Carburetor O-ring Kits? 05 Sep 2022 12:59 #873391
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 512
Hello Ed (Ness) I figure I'd catch Ya' here again. Speaking about these 34 CV's.
I'm giving up on them before I et started.
I had seen one of your replies about putting red Loc-Tite on the small screws for the  throttle blades?
As I was checking mine. All the air mixture needle screws on top are free. The 4 bowl drain screws are free.
Bowls were spotless inside. The 4 slides and rubber diaphragms are great no holes or rot.
So I decide to put a small custom #1 phillips bit my homemade JIS bit on those little screws! And stopped before I stripped the 1st one! I just knew the feeling! it would not loosen. I've never touched these style carbs before. I'll let someone who knows? Do you heat them little screws 1st? to remove?  I heard they peen the back of screw also after installation?
So I am selling them. I don't need anymore headaches for a few dollars. I still use eBay.
Thanks
Marty in Buffalo
Any Interest In Carburetor O-ring Kits? 05 Sep 2022 13:21 #873392
  • Nessism
  • Nessism's Avatar Topic Author
  • Thank you received: 2673
Thanks
Marty in Buffalo
Hi Marty,
CV34's are Keihin carbs for the 750/4 bikes.  What you have there are Mikuni BS34 carbs.
There is no reason to remove the throttle plates, normally.  Why are you trying to do so?  If necessary, the screws are #2, not #1.  Before trying to remove them, I'd use some heat if they don't volunteer to come out.  A metal rod, heated red-hot, touching on the screw for a minute or so, will transfer heat into the screw and (hopefully) make them easier to remove.  Again though, leave them alone unless you have a good reason to take them out.
The reason to remove the screws on the Keihin CV34's, is for the choke plates, which you have to remove in order to ungang the carbs.  I sometimes remove the throttle plates to replate the hardware, when doing one of my 100% concourse restorations.    Otherwise, leave well enough alone.
Hope this helps.
Last edit: by Nessism.
Any Interest In Carburetor O-ring Kits? 05 Sep 2022 14:54 #873395
  • z1kzonly
  • z1kzonly's Avatar
I was going to un-gang, everything, as the bodies were spray bombed black, I planned on glass beading everything.
This whole assembly is ugly as FK!
But like I say, to much labor, time and aggravation to do so. for so little profit.
I have no use for these, only intention was to flip for a profit.
I have never used these or even tuned them. Never got into the J model engines. I'm strictly 1973-1980.
I do have a little mini propane (crackpipe ) torch that would work.
Thanks.
Any Interest In Carburetor O-ring Kits? 05 Sep 2022 15:18 #873397
  • z1kzonly
  • z1kzonly's Avatar
This little guy works great for electrical heat shrink tube also, Its pretty cool,  Takes that small butane cylinder to fuel it. I took it from my son when he was about 13-14! That was 24 yrs. ago!
Any Interest In Carburetor O-ring Kits? 05 Sep 2022 15:26 #873398
  • Nessism
Gack! Hard STOP!
Any Interest In Carburetor O-ring Kits? 05 Sep 2022 16:12 #873399
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1853
What a mean dad taking your kids beer…. Lol
Any Interest In Carburetor O-ring Kits? 05 Sep 2022 16:29 #873400
  • z1kzonly
  • z1kzonly's Avatar
The Torch, not the beer! I hope he was not using the torch for anything bad!!!
But Then! I went to the Bahama's
For: The vertical crack! With a little Bush!
Last edit: by z1kzonly.
Any Interest In Carburetor O-ring Kits? 05 Sep 2022 17:11 #873402
  • mopguy
  • mopguy's Avatar
  • Thank you received: 168
I am interested in a set o rings for both carburetors as I have 1980 KZ750 Ltd. and a 1981 KZ1000 Ltd., you never know when you are going to need them
Any Interest In Carburetor O-ring Kits? 06 Sep 2022 07:16 #873440
  • Nessism
I'm working on collecting the last couple of sizes needed for your 750.  Stay tuned.  Regarding the '81 1000, those are CV carbs, right?  If so, I've got that set covered now.
Any Interest In Carburetor O-ring Kits? 06 Sep 2022 11:47 #873463
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
  • Thank you received: 34
got any more o-ring kits for cv bs34?
1982 KZ1100D1
Any Interest In Carburetor O-ring Kits? 06 Sep 2022 15:02 #873478
  • Nessism
Lots of them.  Send me a PM if you want to purchase.
Any Interest In Carburetor O-ring Kits? 06 Sep 2022 15:54 #873480
  • Gdailey2112
  • 82 KZ1100D1
price for kit plz
you know, for the preferred customer discount lol
1982 KZ1100D1
