KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 09:16 #872386
  • BlackEyeCafe
  • BlackEyeCafe's Avatar Topic Author
  • Thank you received: 3
Hello KZ communityI have been having trouble starting my 1977 KZ650.
After tearing the carb down and re-leveling the floats it still won't start.
Today I noticed when trying to start that the 3rd carb from the left was spitting fuel.  Can anyone help guide me to a resolution?
Thanks in advance.
Btw i searched the forum first and the first 10 results did not provide a solution
1977 KZ650 C
Jets - Main 115 - Pilot 17.5 - Needles - Position 3 - NGK BR7ES
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 09:32 #872388
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 366
Just where is the fuel spitting from?  The overflow port/tubes or out the intake bell of the carb?
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 09:34 #872389
  • BlackEyeCafe
It's coming out the intake and into the air filter pods
IMG_0846.MOV
1977 KZ650 C
Last edit: by BlackEyeCafe.
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 10:18 #872390
  • F64
  • F64's Avatar
  • 81-KZ440D2
  • Thank you received: 351
pull the plugs.
are your plugs fouled?
81-KZ440-D2.
LIC, NY
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 10:38 #872391
  • BlackEyeCafe
The 3rd was soaked in fuel and all had a little soot built up
1977 KZ650 C
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 10:52 #872392
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1853
You can save that plug so you can test, use a propane torch and heat the ceramic and earth strap. It will take some time but eventually the ceramic will start to lighten, continue to heat till the whitest color is achieved.
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 11:05 #872393
  • Mikaw
  • Mikaw's Avatar
Are all the vacuum nipples installed on the carb holders. If it’s not flowing out of the overflow tube then it not likely to be float level, unless the overflow tube plugged.
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 11:07 #872394
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1896
It could be stuck open float needle valve. Try knocking on bowl to free the valve.
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 12:43 #872396
  • BlackEyeCafe
Thanks everyone. I’m going to try all those things. I will let you know what happens
1977 KZ650 C
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 13:52 #872398
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1460
How's the valve clearances ?
If 3 is too tight it may not be seating and blowing back.
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 14:08 #872400
  • BlackEyeCafe
So I tried everything except torching the plugs because I checked for spark and all 4 plugs were working well.
Could this be a timing issue or air screw issue?  I did the valves and did not touch the Dyna ignition after that, would I be better to re-adjust the timing?
1977 KZ650 C
KZ650. Carb #3 spitting fuel out. Wont start 17 Aug 2022 14:14 #872401
  • BlackEyeCafe
That is my main concern. I just went back over the math and I may have “mis-mathed” on # 3. Thankfully I kept notes and it will just mean ordering a new shim and the excitement of tearing apart the top end again…..
1977 KZ650 C
