You win a few, and lose a few... 14 Aug 2022 19:09 #872250
  • Wheelhop
  • Wheelhop's Avatar
  • Thank you received: 292
Just curious what is in the boiling pot?  Water?  Or is it a combination of any chemicals?
thanks for video.
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
You win a few, and lose a few... 15 Aug 2022 04:58 #872274
  • Nessism
  • Nessism's Avatar Topic Author
  • Away
  • Thank you received: 2659
thanks for video.
Details in the videos.  Water with some lemon juice added.  I've used that before and it cleans well, it also turned the metal dark on the set I did.
You win a few, and lose a few... 15 Aug 2022 05:41 #872277
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1008
They look like new!  Is that throttle return spring installed in the groove on the bottom?
You win a few, and lose a few... 15 Aug 2022 16:34 #872312
  • Nessism
  • Away
Photo suggests the spring is NOT in the groove.  Good eye!  I'll fix that!  And speaking of springs, I've often wondered which way the hook/loops are supposed to be oriented, on top and bottom points.  Please share if anyone knows.
Edit: These carbs are for sale, if anyone is interested, please PM me.  I've got another, very similar, set arriving today, so gotta make room...
Last edit: by Nessism.
You win a few, and lose a few... 15 Aug 2022 18:48 #872316
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1843
FWIW. The parts manual show the spring with top hook open away from engine and bottom hook open towards engine.
You win a few, and lose a few... 15 Aug 2022 19:12 #872317
  • Nessism
  • Away
Thanks for the info.  So obvious...why did I miss it?
The new set, just broke down, has air screws, and slightly different bodies and slide lift mechanism parts.  An earlier set I think.  They aren't pristine, like the set I posted yesterday, but a really nice project set nonetheless.  I'll post the numbers in a little while.  Maybe I should start a VM26 carb thread?  Describing the difference between the different sets?  Guys like you can help me fill in the blanks, because I'm not an expert on all the different varients.
You win a few, and lose a few... 16 Aug 2022 22:16 #872367
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 511
Hi Ed - Ness! Here is a win! On a set of old school, round slide 34mm Mikuni's. I just bought these, just because!? They looked cool! I used to run the popular 37.5 Mikuni super-pro carbs back with a 1260 & 1327. But these were spotless on the inside! I'm not a fan of the old floats that just slide up and down on pins, did not ever attempt float adjustments? These carbs work with a FBG 4 into 1 Lectron cable. I thought they would go with a 1197 high comp with Andrews 8X cam i'm working on.  I'm going to sell off soon. As an option to a stock 1015 engine. I just bored top case for the big liners.
Anyone ever use these old dirt bike carbs? With these style floats? Just curious. All carbs are getting expensive nowadays!
Marty in Buffalo
You win a few, and lose a few... 17 Aug 2022 06:08 #872371
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 494
Those do look cool, but it's going to be tricky to reach those choke plungers.  Maybe just adding choke on the #4 cylinder will be good enough?  :)
My dad's '74 Z1
'00 ZRX1100
You win a few, and lose a few... 17 Aug 2022 09:30 #872387
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 360
Ed I would be interested in such a post regarding the differences between the vm26 carbs.  As I have posted in the past I started to gather some info on the vm26 and vm28 carbs in the past but lost interest at some point. I have much more info on the vm24 carbs than the larger ones. It would be interesting to learn the differences between the IDs and internal parts between them, and maybe info on which models they were used on.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
You win a few, and lose a few... 18 Aug 2022 06:39 #872426
  • DOHC
  • DOHC's Avatar
I'm also interested.  It seems like there were many changes made to the VM26 over the years.
Some folks here say certain VM26 are among them best kz carbs (early, with fuel screws?), while Wired George claims that the '79 VM26 pumpers are "essentially un-tunable."
It would be great to see all of the differences documented.
My dad's '74 Z1
'00 ZRX1100
You win a few, and lose a few... 18 Aug 2022 14:48 #872442
  • hardrockminer
This has been quite helpful for me.  Disregard the hen scratching.  The blue numbers are the original.
Last edit: by hardrockminer.
You win a few, and lose a few... 18 Aug 2022 15:44 #872445
  • gd4now
  • gd4now's Avatar
Yes I do have that one and this one as well which is much like it  But neither of them have any info about the ID stamped on any of the carbs or differences between internals as your notes show may or may not be what the tables show. Also have posts from here and other sites as well as some info from parts lists and supplier sites as well.
1977 KZ650 B1
This is my Z
