Need help getting carbs for 1985 Kawasaki ZN700 22 Aug 2022 13:11 #872650
  • borop18
  • borop18's Avatar Topic Author
  • Thank you received: 0
@rstnick, do you mind sharing a link to Pablo's tutorial?
I couldn't find stock carbs for the ZN700, so I got a set of Keihin CVK from a 1985 ZL750 Kawasaki Eliminator, getting them ready to install on my ZN700.
Need help getting carbs for 1985 Kawasaki ZN700 22 Aug 2022 14:23 #872652
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1895
Need help getting carbs for 1985 Kawasaki ZN700 22 Aug 2022 15:50 #872657
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2672
Did you join the 650 site I linked earlier?  The linked thread has tons of useful info about putting CKV carbs on your bike.
Need help getting carbs for 1985 Kawasaki ZN700 22 Aug 2022 16:27 #872658
  • rstnick
  • rstnick's Avatar
  • Thank you received: 373
Yes, the information is on the 650 site which you will need to join to see.
Login (kz650.info)
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Need help getting carbs for 1985 Kawasaki ZN700 23 Aug 2022 13:24 #872712
  • borop18
Waiting on account aproval.
Need help getting carbs for 1985 Kawasaki ZN700 25 Aug 2022 10:04 #872827
  • borop18
So, I finally got the carbs ready to install and now the bike won't crank.
Checked all the fuses, they are good, there is power when I turn the key, but nothing happens when I press the run switch (checked the switch with a multimeter as well and it's good). Also checked the starter relay and that's good as well, when I apply 12V from the battery to the two contacts on the relay, the bike cranks.
I am suspecting the IC igniter, can that cause this issue?
Any ideas what to check next?
Need help getting carbs for 1985 Kawasaki ZN700 25 Aug 2022 11:02 #872831
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
No, not the IC igniter but the side stand or clutch leveler safety switch if the engine is not in neutral.
Need help getting carbs for 1985 Kawasaki ZN700 25 Aug 2022 11:10 #872835
  • borop18
It is in neutral and it's on the center stand with the side stand up.
Need help getting carbs for 1985 Kawasaki ZN700 27 Aug 2022 06:30 #872933
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2051
The switches can malfunction. It would be worth a minute or two to check them. Also check the Run Off Run switch for proper function. If they check out, then a careful, systematic check of the entire starter circuit is in order.
There is an excellent tutorial in the articles section of KZR.
The following user(s) said Thank You: borop18
Need help getting carbs for 1985 Kawasaki ZN700 27 Aug 2022 06:38 #872935
  • TexasKZ
  • TexasKZ's Avatar
Well, I was about 93.8% sure that Wookie58 had posted a diagnostic tutorial in the Articles section, but I’ll be hanged if I can find it. I guess I need a tutorial on finding tutorials
Need help getting carbs for 1985 Kawasaki ZN700 27 Aug 2022 09:56 #872940
  • JR
  • JR's Avatar
  • Thank you received: 429
Was looking for that yesterday also. Dont think it made it to the Filebase but if you go Search Tab, Keywords Fault Finding, User name Wookie58 that should get you to his post with the pdf
Last edit: by JR.
Need help getting carbs for 1985 Kawasaki ZN700 27 Aug 2022 18:06 #872968
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
The following user(s) said Thank You: TexasKZ, Wookie58, borop18
