  • Page:
  • 1
Supporting carbs after replacing air box with pods 02 Jun 2022 07:13 #868032
  • Missile2511
  • Missile2511's Avatar Topic Author
  • Thank you received: 2
I saw where someone with pod air filters on his kz650 used zip ties to support the front of his carbs to substitute for the support that the air box offered. He ran ties from the frame down to and around the air screw flanges on the carb body. It seems to make sense, is anyone else doing that?
Joe
Supporting carbs after replacing air box with pods 02 Jun 2022 07:50 #868037
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 648
Carb bounce will split after market carb to head boots. Cable ties are made of nylon and will stretch so eventually will not achieve the desired effect, also its an untidy heath robinson bodge.
It's simple to make a couple of straps which will hold the carbs rock solid and look tidy at the same time.
Z1000J2 somewhat modified!
The following user(s) said Thank You: ThatGPzGuy, Rick H.
Supporting carbs after replacing air box with pods 02 Jun 2022 07:53 #868039
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1843
K.I.S.S. genius idea there Warren
The following user(s) said Thank You: kzstreetfighter71, Warren3200gt, Missile2511
Supporting carbs after replacing air box with pods 02 Jun 2022 08:44 #868040
  • Missile2511
Thanks Warren, that is a much better idea. Did you use 2 straps on the outboard carbs?
Joe
Supporting carbs after replacing air box with pods 02 Jun 2022 08:52 #868041
  • Warren3200gt
Joe
No, on carbs 2 & 3. The cam cover bolt on those two carbs is directly behind the mix cover screw on those two.
Last edit: by Warren3200gt.
Supporting carbs after replacing air box with pods 02 Jun 2022 09:07 #868042
  • Missile2511
Got it. Thanks a million for the great upgrade.
Joe
Supporting carbs after replacing air box with pods 03 Jun 2022 05:33 #868114
  • Bama704
  • Bama704's Avatar
  • Thank you received: 28
For what it's worth, I had pods on my KZ900 for 8 years and never had any issues with them being unsupported.
1977 KZ900
Carbs are late model 1975 28mm
Supporting carbs after replacing air box with pods 03 Jun 2022 16:56 #868170
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
  • Thank you received: 443
This has worked well for the past 10 years. Although I have to agree with Bama, never really had an issue before installing this. I did so after taking a real hard jolt on a pot hole one day. Put this on so as a precaution.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Supporting carbs after replacing air box with pods 04 Jun 2022 05:50 #868191
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
A thousand ways to skin a cat.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Supporting carbs after replacing air box with pods 06 Dec 2022 15:46 #877577
  • LATER
  • LATER's Avatar
  • Thank you received: 0
Man! l`m enjoying these pages!
  • Page:
  • 1
