  • Page:
  • 1
Fed up with my motion-pro sync gage 09 Oct 2021 13:49 #856438
  • ckahleer
  • ckahleer's Avatar Topic Author
  • Thank you received: 133
I want to replace my Motion-Pro fluid gage with something I don't have to worry about sucking fluid out if the vacuum gets to high.
I only use it a couple times a year, so don't want something too pricey. I have heard bad reviews on the $35 e-bay gages.
I can get a Morgan Carbtune for around $135 or maybe this dial gage. Any recommendations on what to or not to get would be appreciated.
Thanks
www.amazon.com/ALPHA-MOTO-Synchronizer-S...dExvZ0NsaWNrPXRydWU=
94 KE100
81 CM200t
82 KZ305
79 KZ400
85 VT 500c
85 VF1100c
Fed up with my motion-pro sync gage 09 Oct 2021 15:15 #856452
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
The Morgan unit is quality.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: KZB2 650, Nessism
Fed up with my motion-pro sync gage 09 Oct 2021 15:20 #856453
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2675
Go Morgan or go home.
Fed up with my motion-pro sync gage 09 Oct 2021 16:08 #856462
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
I sync carbs with my Boehm sync gauge (Made in Germany) for more than 25 years. Stay away from cheap china knock off clocks.
Look at the clock hands and you will see the difference in precisin....
Last edit: by Scirocco.
Fed up with my motion-pro sync gage 09 Oct 2021 16:47 #856464
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1858
+1 on the Morgan
Fed up with my motion-pro sync gage 09 Oct 2021 17:23 #856468
  • Thank you received: 2829
Below is a picture of what I use; they work great!  They look very much like the ones in your posting.  Previously I had a set of cheap gauges and they were crap!  Ed
Fed up with my motion-pro sync gage 10 Oct 2021 06:10 #856479
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
I have both the Morgan Carb Tune and the gages that Scirocco mentioned.  They each work well, but the Boehm gages are super accurate.  I had to go in a round about way to purchase them as the retailer didn't want to sell in the USA, so I bought them from a place in England.  Just make sure to follow the directions with the gages or risk damaging them.  I use the Carb Tune as a backup to verify the readings I get with the gages.  Cheap gages get you nothing but frustration in an important area.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Fed up with my motion-pro sync gage 10 Oct 2021 06:27 #856481
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
What brand are those Ed?
Fed up with my motion-pro sync gage 10 Oct 2021 07:45 #856488
The set I have doesn't have a brand name on it, but it looks exactly like these:
www.amazon.com/ALPHA-MOTO-Synchronizer-S...a-451671400718&psc=1
The following user(s) said Thank You: TexasKZ
Fed up with my motion-pro sync gage 10 Oct 2021 08:43 #856493
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
I have a set of the 4 cheap blue gauges, and they sort of work.
If I were to get a better tool, I'd probably get the digi sync.
thedigisync.com/
They claim it's self calibrating, which I'm guessing is really just self-zeroing at turn on.
They also say it reports the peak instead of the average, which maybe makes the measurement a bit more accurate?
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: ThatGPzGuy, Mikaw
Last edit: by DOHC.
Fed up with my motion-pro sync gage 10 Oct 2021 20:03 #856519
  • ckahleer
Follow up.
I just ordered the Morgan Carbtune. I could have got a decent Dial gage unit for $100, but the Carbtune for $131 is more compact and looks more rugged.
The digi-sync was more than I wanted to spend, and with a digital read out, you can't read at a glance. Also requires batteries or power adapter.
94 KE100
81 CM200t
82 KZ305
79 KZ400
85 VT 500c
85 VF1100c
Last edit: by ckahleer.
  • Page:
  • 1
