Extremely high rpms on start. 07 Oct 2021 12:44 #856326
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
I didn't even notice that. Thank you! This probably won't fix the issue but never the less it needs to be fixed.
Trust me, it will fix your high rpms!!! If you think so leave it as it is
Last edit: by Scirocco.
Extremely high rpms on start. 07 Oct 2021 14:24 #856332
  • Qsmothers3
  • Qsmothers3's Avatar Topic Author
It definitely helped! Now it idles at 3000 and not 6000. Still gotta figure out how to get it even lower though
Extremely high rpms on start. 07 Oct 2021 22:47 #856350
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Did you try to back out the idle adjustment screw?
Extremely high rpms on start. 08 Oct 2021 06:14 #856356
  • Qsmothers3
Yeah its backed all the way out. Its gotta be a vacuum leak some where...I just don't know where.
Extremely high rpms on start. 08 Oct 2021 06:36 #856358
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2678
Is the airbox installed w/filter inside?
The following user(s) said Thank You: Qsmothers3
Extremely high rpms on start. 08 Oct 2021 09:04 #856368
  • Qsmothers3
Yes the airbox is installed with new air filter. Do you think soaking the filter in sae 30 oil will help??
Extremely high rpms on start. 08 Oct 2021 09:06 #856369
  • Qsmothers3
When you say filter inside air box do you mean there is supposed to be a filter inside the air box and inside the filter cap above the air box? I only have one filter and it is in the filter cap above the air box.
Extremely high rpms on start. 08 Oct 2021 09:58 #856374
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
Did you sync the the carb butterflys by service manual?
Are both butterflys fully closed? a pic would help
Extremely high rpms on start. 08 Oct 2021 11:45 #856376
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Just to follow up on what Scirocco said, can you actually get to a point with the carbs on the bike where you can see the butterfly valves?  If so, what position are they in?  Open or closed?  If open, how much are they open?  From a personal standpoint, I have never seen a vacum leak cause a 3,000 RPM jump in engine speed, let alone a 6,000 RPM jump.  Not unless you are feeding jet fuel into the vacum leak.  Something else is going on with your carbs and I believe you need to go back to square #1 and bench syncing them.  Then install and adjust.  Just my humble opinion.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
The following user(s) said Thank You: Scirocco
Extremely high rpms on start. 08 Oct 2021 18:44 #856401
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Extremely high rpms on start. 09 Oct 2021 15:04 #856450
  • Qsmothers3
Update!! I took the carbs off, bench synced them and low and behold the ol girl fired right up! Idle is at a cool 1100 rpm! Took it out for a spin and it has great throttle response all around a smooth ride! Need to get some new tires and I think she's ready to hit the road!! Thank you all for your help!!
Extremely high rpms on start. 09 Oct 2021 15:22 #856454
  • Nessism
  • Nessism's Avatar
  • Away
Great job!  Maintenance for the WIN.  Father Kawasaki (service manual) knows best!
BTW, now do a vacuum sync for the final tune.
