  • Page:
  • 1
1980 750 four ltd 10 Aug 2021 16:14 #853537
  • MarcG
  • MarcG's Avatar Topic Author
  • Thank you received: 0
Good evening all does anyone no what size screws are used to secure the airbox in place my mechanic returned my bike with them missing wont go back to this guy, thx
1980 750 four ltd 10 Aug 2021 16:30 #853538
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1849
The following user(s) said Thank You: Nessism, MarcG
Last edit: by Mikaw.
1980 750 four ltd 11 Aug 2021 05:45 #853559
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
Messing w the airbox might not be necessary when removing the carburetors. I'm assuming that's why the screws are missing.  It could be that the airbox ducts are hard & need replacing >> the ducts are still available.
The following user(s) said Thank You: MarcG
Last edit: by martin_csr.
1980 750 four ltd 11 Aug 2021 15:56 #853607
  • MarcG
Thanks Mikaw your ride looks great
1980 750 four ltd 11 Aug 2021 16:01 #853608
  • MarcG
Mechanic returned bike without fixing leaking overflow but lost air box screws all boots front n back r new #4 still dripping a bit I’ll work on that thx for the input ride safe
1980 750 four ltd 11 Aug 2021 16:48 #853610
  • Mikaw
  • Mikaw's Avatar
MarcG thanks. Here’s a picture of it just after a good detailing.
Overflow is typically a float level too high. Do you have a manual?
1980 750 four ltd 11 Aug 2021 18:31 #853617
  • JR
  • JR's Avatar
  • Thank you received: 429
Also possible on these carbs is a hairline crack in the drain tube
If you need a manual click the Articles tab above. Select Service manuals and pick the gpz750 manual
  • Page:
  • 1
