  • Page:
  • 1
Gas tank cap 01 Aug 2021 21:17 #853017
  • Ojisan rider
  • Ojisan rider's Avatar Topic Author
  • Thank you received: 63
Aloha guys. I hope I'm posting this on the right section.
For the life of me, I can't find my original gas cap. It should be somewhere as I don't think I'll throw away something I need down the line. Anyway, my question is just that. What do you guys use if you need a gas cap. Brand new Chinese copy or good used cap?
Found several on evilbay so getting one should be no problem. I'm just not sure about the quality of Chinese cap. If I decided to get the used one, I'll be sure to change the gasket, so don't worry about that.
Any thought or experience?
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
Gas tank cap 02 Aug 2021 04:00 #853020
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
I would buy a used one if I needed one.  Reduce, Reuse, Recycle.
Gas tank cap 02 Aug 2021 05:02 #853023
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
I prefer gently used original or n.o.s.
Gas tank cap 02 Aug 2021 06:06 #853027
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
I installed a repro fuel cap more than 5 years ago. high quality & works-fits fine.
Made in Taiwan & seems to be the same one sold at various places.*
Info on box: 20-0032 FUEL TANK CAP, #51048-1003 (Made in Taiwan).
note: the Kawasaki part number supersedes to 51048-1018 which is the part number for the stock fuel cap on my motorcycle.
PartsNmore Fuel Cap 20-0032: www.partsnmore.com/parts/kawasaki/kz650h/?q=20-0032
* ps: not to be confused w the cheap chinese knockoffs listed on EB.
Last edit: by martin_csr.
Gas tank cap 03 Aug 2021 01:02 #853063
  • Ojisan rider
Thanks guys.
Yeah, I was bit worry about the Cheap Chinese cap, so good used one it is. So far, I haven't see any Taiwan made cap, but I'll try that as well.
Gas tank cap 03 Aug 2021 05:49 #853065
  • martin_csr
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThe fuel caps at PartsNmore, Z1Parts.net & Johnny's Vintage Cycles are probably the same as the one I got.  I've only seen a few on EB made in Taiwan, but they usually cost more.   2FastMoto on EB has a couple, including an Emgo.
This one has the same keys as mine w the same logo, so probably the same.  2fastmoto item 202780280324 also has the same keys but the logo is hard to see. Alternatively, I wouldn't hesitate to get an emgo fuel cap. should be made in Taiwan.
EB. linked this one just to show the key logo. this seller's pricing is usually higher than others.
__________________________________________________________________________________________
Emgo 43-61014. Made in Taiwan.
Gas tank cap 03 Aug 2021 23:06 #853128
  • Ojisan rider
Oooooooooooooh, OK.
Yeah, I saw couple of those, including the 2FastMoto ones. Didn't realize that was Taiwan, but it did cost somewhere in the 20's. Found couple decent looking used cap as well, so not too sure which one I'll go with.
I'm kinda leaning towards the used Black cap I found......................
Gas tank cap 04 Aug 2021 06:07 #853131
  • martin_csr
If a black one is preferred, you could try painting a chrome one with Rustoleum bar-b-q grill paint.  I painted the manifold section of a nice muffler system w silver bbq paint & it has held up without peeling or anything.  I didn't sand or roughen the chrome, just cleaned it with a soft brass jewelers wire wheel to remove rust mostly from the welds.  Alternatively, engine paint may also work.  but I know the rustoleum bbq paint sticks to chrome.
Gas tank cap 04 Aug 2021 15:09 #853162
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
No eBay APP ID and/or Cert ID defined in Kunena configurationNot cheap but...
  • Page:
  • 1
