  • Page:
  • 1
BS34 question 06 Apr 2021 13:20 #846278
  • davido
  • davido's Avatar Topic Author
  • Thank you received: 286
Should the air screws have springs under them or do they just pop in au natural? I cant see anything on the schematic but what stops them tightening or loosening from vibration?
Also,should I use any type of grease when reassembling the carbs? White grease,? Bearing,? Silicone? Nothing at all?
Thanks for any advice.
CB550
(CB500/4)
(CBX750)
GSF600
KZ1000CSR
XT 600e
BS34 question 06 Apr 2021 14:35 #846282
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1896
davido post=846278Should the air screws have springs under them or do they just pop in au natural? I cant see anything on the schematic but what stops them tightening or loosening from vibration?
Yes, spring,washer, o-ring. I do oil all shafts and sliding parts with silicone oil.
The following user(s) said Thank You: davido
Last edit: by Scirocco.
BS34 question 06 Apr 2021 16:06 #846287
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2673
The photo Scirocco shows is of a Suzuki GS BS Mikuni.  The KZ Mikuni's, at least some of them, have a slightly different arrangement.  The later type for example use an o-ring around the screw up near the head.  The O-ring is larger than the small O-ring that goes on the tip, and there is no washer.  And yes, a spring is needed to keep them from moving.
Regarding grease, silicone grease is best for the O-rings.  Some grease is also good on the pilot screw threads so they don't seize into the carb body which they sometimes like to do.
  • Page:
  • 1
