'77 - '80 KZ1000 Airbox silencer tubes 18 Feb 2021 18:24 #843695
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1866
What is this interesting little item hiding in plan site.
'77 - '80 KZ1000 Airbox silencer tubes 18 Feb 2021 22:29 #843701
  • Kaylinator
  • Kaylinator's Avatar Topic Author
  • Thank you received: 74
Mikaw wrote: What is this interesting little item hiding in plan site.
That neat little nugget plugs in to end of my battery tender cable. When you push the button it tells you what your battery level is at. Thought it could be handy to have around. Let's me know pretty quickly if I'm better off just kick starting it. Canadian bikes don't have the option of turning off the headlight, which drains the battery REAL quick.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
'77 - '80 KZ1000 Airbox silencer tubes 19 Feb 2021 10:24 #843719
  • Mikaw
  • Mikaw's Avatar
So the battery tender on bike cable that includes the quick disconnect will plug into that, then lifting the seat and tapping the button it gives you a real time battery voltage? Can you leave it connected with the bike running? That would show the Dyno output.
Edit. Where did ya get it?
Last edit: by Mikaw.
'77 - '80 KZ1000 Airbox silencer tubes 19 Feb 2021 12:45 #843725
  • Kaylinator
You got it. I haven't tried it out with the bike running yet to see if it would works for that, but I suspect it would.
I picked it up at Canadian Tire. It's made by Motomaster, which is a Canadian Tire brand, but not sure if it could be found stateside too. I mean, if you can buy Helly Hansen, I'm not sure why Motomaster wouldn't go international too.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
'77 - '80 KZ1000 Airbox silencer tubes 19 Feb 2021 13:01 #843727
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 511
This looks pretty close.
www.amazon.com//dp/B00DJ5KE9A
My dad's '74 Z1
'00 ZRX1100
'77 - '80 KZ1000 Airbox silencer tubes 19 Feb 2021 13:33 #843730
  • Kaylinator
DOHC wrote: This looks pretty close.
No sir, it does not look pretty close. It looks bang on. Probably made on the same line.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
'77 - '80 KZ1000 Airbox silencer tubes 19 Feb 2021 17:44 #843745
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1906
The new battery generation.....
'77 - '80 KZ1000 Airbox silencer tubes 28 Feb 2021 14:18 #844259
  • DOHC
  • DOHC's Avatar
DOHC wrote: I'm assuming you don't have the original screws...
I found something that will work in place of the factory screw. It's at least the right type of screw. It's a KTM part, part number 0081030081. I got them for $0.19 each.
The head is a bit small, and it's a torx drive, but the thread pitch and style are basically the same, and the length is the same. So close?
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: Mikaw, Kaylinator
'77 - '80 KZ1000 Airbox silencer tubes 28 Feb 2021 14:41 #844260
  • Mikaw
  • Mikaw's Avatar
I’m sure you could but a small washer under it if it looks a small. But it’s not in any high clamping situation
'77 - '80 KZ1000 Airbox silencer tubes 12 Mar 2021 10:22 #844826
  • Kaylinator
Just took delivery on these from China. They should work well. I order 3x8s as well as 3x10s so I can grind off the tip if desired.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
'77 - '80 KZ1000 Airbox silencer tubes 14 Mar 2021 17:53 #844925
  • Kaylinator
No eBay APP ID and/or Cert ID defined in Kunena configurationTo wrap this up, these look pretty good to me.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
'77 - '80 KZ1000 Airbox silencer tubes 14 Mar 2021 19:46 #844931
  • Mikaw
  • Mikaw's Avatar
Looks like factory.... cool project.
