  • Page:
  • 1
  • 2
GPZ 550 Unitrak 1982 fuel leak in to oil 16 Dec 2020 11:23 #840163
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2677
The float needle and seat are a matched set since they wear in together. Be sure to not mix up the parts or you could get leakage.
The following user(s) said Thank You: vabi
GPZ 550 Unitrak 1982 fuel leak in to oil 20 Dec 2020 03:47 #840357
  • vabi
  • vabi's Avatar Topic Author
  • Thank you received: 0
So, i've fu...d up. Not the first time :)
I 've orderer'd this set:
But, my carbs looks like:
They are supposed to be TK-26.
I'll survive that but the question is will the float seats and needels fit?
The joke is on me.
Last edit: by vabi.
GPZ 550 Unitrak 1982 fuel leak in to oil 01 Jan 2021 23:50 #841015
  • vabi
Ok. So far, so good. I have replaced all the provided jets and seals. Also, I have adjusted the float heights. The leaking is gone.
Now I have to tune it. I know how to sinc them but I have a question about the air screw (next to the vacuum chamber).
How to put it in initially. Is there a number of turns I should go back after I screw it all the way in or something like that ?
I did some research and found that 1 and 3/4 back from full would be a good starting point.
Any tips for what to do after rebuild are welcome.
Last edit: by vabi.
GPZ 550 Unitrak 1982 fuel leak in to oil 02 Jan 2021 14:37 #841064
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
On the Tk26 and Tk27 the adjustment screw is not an air screw, it is a mixture screw. When you turn it out it gets richer. When you turn it in, it gets leaner.
  • Page:
  • 1
  • 2
