  • Page:
  • 1
Wide open throttle on start up, help? 20 Sep 2020 19:08 #835443
  • TheFatArmenian
  • TheFatArmenian's Avatar Topic Author
  • Thank you received: 0
Hi folks,
I just picked up a pretty decent 2001 KZ1000 Police bike. Bike was running totally fine, but then yesterday when I hit the starter button the engine immediately screamed to redline. I dissembled the throttle and everything looks ok, I can see the carbs moving as well. Any suggestions? The bike is totally unrideable and I'm afraid of starting the bike in this condition.
Wide open throttle on start up, help? 21 Sep 2020 14:59 #835490
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
Could be several things.
Did one or more of the vacuum caps come off or split?
One of the vacuum lines come off or split?
Is the throttle shaft hanging up?
Has the petcock failed, causing a flooding condition?
Is a dead pterodactyl stuck in one of the carbs, holding it open?
Wide open throttle on start up, help? 21 Sep 2020 23:03 #835514
  • Highway Magician
  • Highway Magician's Avatar
  • Thank you received: 34
Check the choke assembly. Make sure it isn't on.
Motorcycle builder since 1973. Master Tech. Current bike: 1982 GPZ1100B2.
Last edit: by Highway Magician.
  • Page:
  • 1
