  • Page:
  • 1
All I want to do is ride... and not repair right now. 14 Sep 2020 19:35 #835053
  • KZJOE900
  • KZJOE900's Avatar Topic Author
  • Admin
  • Thank you received: 443
Well, with the DGR right around the corner, I still haven't figured out the cause of my #2 cylinder dropping out. So I didn't feel like diagnosing the coil etc. So I checked it the lazy man's way.
I feel pretty confident the issue is fuel related. Unless is is some kind timing issue. But if it was, #3 cylinder would have an issue as well. So tomorrow I will try spraying starting fluid into carburetor # 2 while the bike is idling. Want to see if idle will increase. Not sure if this will work, but if the rpm's go up, it will further confirm that it is a carburetor issue. I hate the idea of having to take the rack apart for repairs. All I want to do is ride these days. Don't have the time and patience to do repairs anymore. Well, fingers crossed.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: by KZJOE900.
All I want to do is ride... and not repair right now. 15 Sep 2020 00:52 #835061
  • weebeasty
  • weebeasty's Avatar
  • Thank you received: 2
hi
sounds familiar to me... have you tried new plugs ? they can run fine when in idle but can fail when under load even though they work at idle.
another cause can be the valve clearance to tight. will run fine when cold and maybe idle but when it gets warm it can cause the valve to be ever so slightly open and that will cause misfire or complete drop out.
The following user(s) said Thank You: KZJOE900
All I want to do is ride... and not repair right now. 15 Sep 2020 04:22 #835064
  • KZJOE900
  • Admin
weebeasty wrote: hi
Thanks WeeBeasty, I have already eliminated the plug by swapping with a plug from another working cylinder. I agree, I should check the valve clearance next. Free time is my problem right now. I do suspect the clearance is okay since I really don't put on a lot of miles. But they do need to be checked and I would rather do that first than taking apart the carburetor rack. Will post my solution here once I resolve this. Thanks again.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
All I want to do is ride... and not repair right now. 15 Sep 2020 10:07 #835094
  • F64
  • F64's Avatar
  • Away
  • 81-KZ440D2
  • Thank you received: 349
If you had one of these you may be able to use it to view the carburetor throat to see if fuel is pulling out of the needle jet.
wireless endoscope
I've used my phone for this as well.
81-KZ440-D2.
LIC, NY
All I want to do is ride... and not repair right now. 15 Sep 2020 10:10 #835095
  • Saablord
  • Saablord's Avatar
  • Thank you received: 59
Compression test?
I like the starter fluid idea. Play with the air/fuel screw as well
Last edit: by Saablord.
All I want to do is ride... and not repair right now. 30 Nov 2020 05:19 #839218
  • TexasKZ
  • TexasKZ's Avatar
  • Away
  • Thank you received: 2050
Any news?
All I want to do is ride... and not repair right now. 30 Nov 2020 08:10 #839228
  • mopguy
  • mopguy's Avatar
  • Thank you received: 168
I had the same problem on my KZ750, it ended up being a dirty carburetor. I cleaned it, problem solved.
All I want to do is ride... and not repair right now. 25 Jan 2021 18:26 #842404
  • KZJOE900
  • Admin
Sorry guys, but life keeps getting in the way so I haven't had any time to work on the bikes. My weekends seem to always taken by work, or something else. It really hurts it being the ideal riding season down here. I'll keep hoping for a free weekend.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • Page:
  • 1
