VM 28mm 30 Sep 2020 14:43 #835934
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
I know mine are 28’s
Last edit: by Mikaw.
VM 28mm 01 Oct 2020 15:11 #835992
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 503
Mikaw wrote: I know mine are 28’s
Mine are also VM28SS from a 1978 Z1-R. I have two sets. Both are stamped 104 0A.
My dad's '74 Z1
'00 ZRX1100
VM 28mm 02 Oct 2020 10:15 #836026
  • Zilla
  • Zilla's Avatar Topic Author
  • Thank you received: 11
Mikaw wrote:
gd4now wrote: Dumb me, I mixed up 102 and 120. I edited my last post to fix this, but still not sure which model or year the 120/5 came on. I do have info of 1201 on a 79 or 80 KZ1000A
I can see the stamp on mine in the same place just can’t make it out.
Just FYI
To the best I figure based on Partzilla and internal parts my set is from a 1980 Kz1000 LTD. see photo of stamped number on the flange
1986 KZ1000P
2005 Vmax
VM 28mm 02 Oct 2020 10:17 #836027
  • Zilla
I also got the same measurement on mine so I know there 28s, but mine have the idle screw on the bottom instead of the top.
1986 KZ1000P
2005 Vmax
VM 28mm 02 Oct 2020 10:29 #836029
  • Zilla
Bout the best pic I can get.
1986 KZ1000P
2005 Vmax
VM 28mm 02 Oct 2020 11:24 #836037
  • kevski
  • kevski's Avatar
  • Thank you received: 154
I have had three sets of 26's on the bench at one time identical in every way except the numbers on the side.
The following user(s) said Thank You: Zilla
VM 28mm 02 Oct 2020 12:03 #836040
  • Mikaw
  • Mikaw's Avatar
Zilla, looks like P9 over Y4. I guess that’s a year/date code of some kind. The 120 over 5 is the size and type. Just a guess.
VM 28mm 02 Oct 2020 13:38 #836046
  • Zilla
Mikaw wrote: Zilla, looks like P9 over Y4. I guess that’s a year/date code of some kind. The 120 over 5 is the size and type. Just a guess.
That’s what I was thinking, I’m just gonna call it 79/80 models when I’m sourcing parts. Saw another topic on starter plungers I might look into getting.
1986 KZ1000P
2005 Vmax
