GSXR 1100 carbs on a KZ 1000
- Southpaw
18 Jul 2022 05:20
HeyAll,
Has anyone put the 36 mmm flatslide carbs from a 1990 GSXR 1100 on KZ 1000 ??, Came across a set and was wondering if there any good for drag racing application
- kzstreetfighter71
- Atlantic West Coast
Re: GSXR 1100 carbs on a KZ 1000
18 Jul 2022 07:30 - 18 Jul 2022 07:35
Seen guys do it before but the top end of the gsxr has about 8% more of a lean forward and this effects the float bowl. im sure there are fellas here that know more about it but get the facts before you press the buy button.
Last edit: 18 Jul 2022 07:35 by kzstreetfighter71.
- Injected
21 Jul 2022 18:22 - 21 Jul 2022 18:24
Those carbs are CVs and not a "true" flat slide, its a round slide on the motor side. I guess it would depend on any other work that has been done to the motor and if it is a dedicated drag bike or a hot street bike.
I have only seen CV's on hot street bikes not real drag bikes, most use RS series flat slides as they are a racing carb (easy to change main jet) or Lectron carbs which is a all out racing carb (no idle circuit)
It is easier to ride the bike back for the finish line with RS flat slides as they have a low speed circuit, the Lectons not so great at low speed.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 21 Jul 2022 18:24 by Injected.
- TerryK
02 Aug 2022 17:34
I believe those carbs are CVs, not flat slides. I used to run a set of 29mm 750 GSXR flatslide carbs on my mostly stock 1000 and they worked great. Had to swap them out for 33 smoothbores when I went with cams and a ported head.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Southpaw
12 Aug 2022 09:15
Ended up biting the bullet and bought a new set of RS flatslides, thanks for the input
