140/60/18 on stock 3.00" rim
  • kawi810
  • kawi810's Avatar Topic Author
21 Feb 2016 10:37
#711808
i need opinions on what tire to mount on stock gpz 750 3.00" rim . for drag racing .i am looking at the 140/60/18 006 podium
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
  • zukdave
  • zukdave's Avatar
Re: 140/60/18 on stock 3.00" rim
21 Feb 2016 15:40
#711847
That's the tire I run on a 3.5 rim and think it would work better on a 4" rim
as for the 006 it's the stickiest 18" I've ever rode on I'll be ordering a new one this week
from Spencercycle..
www.spencercycle.com/shinko-006-podium-motorcycle-tires/ .
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
The following user(s) said Thank You: PLUMMEN
  • KZB2 650
  • KZB2 650's Avatar
22 Feb 2016 06:57
#711936
Wish they would make the hookup drag radial or the stealth in a 120 to 160, 18 inch size ....... had a buddy that ran a Goodyear slick on his Suzuki 1000 for years on the street.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • kawi810
22 Feb 2016 08:18
#711959
right now i have a battlax bt 45 140/80/18 fits ok .i wonder going down in the aspect ratio to 60 will make much difference?
  • zukdave
  • zukdave's Avatar
23 Feb 2016 16:01
#712180
KZB2 the rubber compound in the 006 Podium is as soft or a little softer than the Hookup.
I've got two season's and about 250 pass on mine and it's on the wear bar's and I still can't spin
it launching on a prepped track and my motor ain't no punk shit it make's good power.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: KZB2 650
  • kawi810
23 Feb 2016 17:22
#712198
ok dave you convinced me . i will buy the 140 /60 18 006 podium. working on my long arm and bottle mount and lowering links i will post pics after this week end .i rarly get to do my own thing on fridays .i am caught up in my work at the tool room .so now is my time to make parts.little machining . a little welding and .Faburcating.
  • zukdave
  • zukdave's Avatar
01 Mar 2016 08:15
#713211
You get the tire yet ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • kawi810
01 Mar 2016 08:51
#713220
no i made the long arm and lowering links and bottle mount that came out ok .
  • kawi810
01 Mar 2016 08:53
#713221
when i get home will post some pics
  • kawi810
02 Mar 2016 03:36 - 02 Mar 2016 03:42
#713368
Last edit: 02 Mar 2016 03:42 by kawi810.
  • kawi810
02 Mar 2016 03:43
#713369
  • kawi810
02 Mar 2016 03:58 - 02 Mar 2016 04:01
#713371
more pics to come
Last edit: 02 Mar 2016 04:01 by kawi810.
