  • Page:
  • 1
Recent Test and Tune Trip 15 Dec 2013 18:16 #615573
  • Hoodftw
  • Hoodftw's Avatar Topic Author
  • Thank you received: 0
I took my mostly stock 1980 750 LTD to the local strip this past weekend with a couple of friends seeing what the bike would do. My best pass was 13.36. I think the bike could do a little better if I could get better with my launches. I was pretty nervous and big wheelie put some fear in me. It was a lot of fun though, we're going to try a sprocket change and a few other things to see if I can get it down in the 12's. There were only 2 other guys on bikes that night. A stretched Busa that did an 8.9 @ low 150's and another guy with a ZX-14 stretched with a wheelie bar that did a couple of low 9 sec passes in the high 140's. He also had a 1200 sportster that my tired old 750 was almost keeping up with. But he had a wheelie bar hahaha!
Attachment timeslip.jpg not found
1980 KZ750 LTD
1980 KZ1000 LTD
1997 VLX 600
New Orleans LA
Recent Test and Tune Trip 15 Dec 2013 18:28 #615574
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
  • Visitor
www.dragtimes.com/Kawasaki-KZ-Timeslip-8918.html
check out 60 foot times doesn't add up??????????
Last edit: by 4TheKZ1000.
Recent Test and Tune Trip 15 Dec 2013 19:18 #615576
  • Hoodftw
It doesn't look like those lines match up, but the 60 ft time is the 2.022# not the 5.4 secs. That's the 330 ft time. I don't know what the DIAL is for? The 1/8 mile is 8.4 @ 81. Seems I ran a little better than that 750E.
1980 KZ750 LTD
1980 KZ1000 LTD
1997 VLX 600
New Orleans LA
Recent Test and Tune Trip 15 Dec 2013 20:21 #615578
  • JR
  • JR's Avatar
  • Thank you received: 429
That's great. Thanks for posting. Always amazes me what these old bikes will do and how mine keeps going year after year.
Your post makes me proud to ride 30+ year old 750.
Recent Test and Tune Trip 16 Dec 2013 17:25 #615665
  • Hoodftw
JR: It really is incredible how powerful these bikes are for how old they are. I've smoked my friends modern 900 and 1100 cc cruisers and on a bike that I paid $325 for hahaha! Now I'm itching to bring my big bore 1000 LTD to the track and really scare myself!
1980 KZ750 LTD
1980 KZ1000 LTD
1997 VLX 600
New Orleans LA
Recent Test and Tune Trip 16 Dec 2013 18:20 #615667
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
  • Thank you received: 83
Id like to get my bike to the strip. But my woman wont let me run it. She said shes leaving me if i do. But id really like to see what its got.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Recent Test and Tune Trip 16 Dec 2013 19:10 #615677
  • Hoodftw
Tell her its the safest place to run your bike. No cops, no one talking on their cell phone or pulling out in front of you. Don't expect to put down crazy fast passes. It's all in the launch and to do it well you have to have tons of experience and balls much larger than my own. After a couple passes I realized how difficult it is to do well consistently. As far as tuning goes, we didn't mess around too much as I was just getting used to launching on a track. But eventually we got around to advancing and retarding the timing and letting air out of the back tire. My best passes I was running 20 PSI :blink:
1980 KZ750 LTD
1980 KZ1000 LTD
1997 VLX 600
New Orleans LA
Recent Test and Tune Trip 16 Dec 2013 19:14 #615679
  • zukdave
  • zukdave's Avatar
  • Thank you received: 229
My G/F was like that till she spent a week end campin at the
drag strip with me and my buddy's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Recent Test and Tune Trip 17 Dec 2013 04:17 #615699
  • Powerstroke_fan
Ya launches are difficult. I practice my launches out in the road in front of house all the time. but its still not quite the same as on the track. I almost always am running around 18 to 20 psi in the rear. As already said, The wheelies and the rear tire breaking loose is what gets me.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Recent Test and Tune Trip 17 Dec 2013 05:21 #615703
  • zukdave
  • zukdave's Avatar
It's all about the seat time at the track practice on the street
help's get the sequence of launching the bike but will not make up for the traction
at the track..
Next time out don't worry about making full pass's just work on your 60 ft time's
and the 1-2 shift the ET's will come down.
Here's a goal for you my little bike's gone
7.63@89.73 w/ 1.71 60 ft. 1/8 mile no bar.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: by zukdave.
Recent Test and Tune Trip 18 Dec 2013 09:49 #615814
  • Hoodftw
My best 60 foot time was 1.91. It felt really fast until I watched a video of one of my passes and it looks painfully slow off the line. I geared the bike down a little bit when I did the 530 chain conversion. My friends and I will be going again in January and I'm going to try losing a tooth on the front sprocket and see if I can get the times down a little bit. One of the cylinders has a bad ring and low compression so if I can address that issue, probably wouldn't hurt either.
1980 KZ750 LTD
1980 KZ1000 LTD
1997 VLX 600
New Orleans LA
Recent Test and Tune Trip 18 Dec 2013 16:43 #615858
  • zukdave
  • zukdave's Avatar
If it wheelie's now gearing down will make it worst.
Get a strap setup and suck the front down as far as you can will help.
If you plan on running it alot I'd get a longer swing arm to swap in for track trip's.
Used arm's 6-8 inch longer can be found cheap.
I pulled my arm tonight to add 5 1/2 inch will put me 8" over stock wheel base
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • Page:
  • 1
