Old / cracked / otherwise unusable VM28SS (Z1) carb holders
  • slmjim+Z1BEBE
  • Topic Author
22 May 2024 06:13 - 22 May 2024 08:08 #899510 by slmjim+Z1BEBE
Will only be used for mounting a rack of Z1 carbs on a larger board to be used as a vertically-adjustable support while further development in the use of glass "dummy float bowls" takes place.
We've commissioned some prototype dummy glass 'float bowls' from a local custom laboratory glassblower, and they vary a little in height, necessitating some vertical adjustability of racks.
We don't care about radial cracks that would cause vacuum leaks, only that there is no severe cracking around the outer periphery that would compromise the ability of the holders to support the weight of a rack without sagging, although mounting the holders 'upside-down' might be a workaround for that.  Missing rubber vacuum port caps is OK.  No vacuum port at all is OK.  If in doubt, ID of the holders needed at the carb end is 32.5mm ~ 33mm.  Prefer a matched set.
We will gladly pay shipping within CONUS.
This project is further experimentation in the development detailed in this thread:
www.kzrider.com/forum/3-carburetor/61368...n-setting-fuel-level
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Last edit: 22 May 2024 08:08 by slmjim+Z1BEBE.
22 May 2024 10:31 - 22 May 2024 10:33 #899528 by sf4t7
Just some suggestions:
See photos attached for the fixture I made to mount carb rack.  I found just using the end two carb holders to hold the rack is simpler to align and level.  (but still have four holes to bench sync slides)  A small bar clamp holding the rack to the board is easier than trying to use hose clamps for the carb necks. More than likely you already have a fixture made.
If no one has some old holders to send, as an alternative some el cheapo chinese ones from evilbay with free shipping would work.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
  • Last edit: 22 May 2024 10:33 by sf4t7.
    The following user(s) said Thank You: slmjim+Z1BEBE
    23 May 2024 08:11 #899571 by Mikaw
    I’m sure I can help. I’ll dig into my stash and let ya know.
    23 May 2024 08:14 - 23 May 2024 08:15 #899572 by Mikaw
    Great minds think alike. I need to drill the hole to do the bench sync.
  • Last edit: 23 May 2024 08:15 by Mikaw.
    The following user(s) said Thank You: slmjim+Z1BEBE, sf4t7
    23 May 2024 08:54 #899574 by sf4t7
    Mikaw, the plastic conduit clamps are to hold the 1/2" pvc pipe the temp fuel supply jug hangs from...
    Scotty
    1974 Z1A
    1015
    welded Z1 crank
    Andrews 1X Cams
    Delkevic 4 into 1
    23 May 2024 15:54 #899591 by sf4t7
    Btw Mikaw, my fixture was copied from yours and I added the legs to the top so I can flip it over to access the jets and floats
    Scotty
    1974 Z1A
    1015
    welded Z1 crank
    Andrews 1X Cams
    Delkevic 4 into 1
    24 May 2024 07:01 #899632 by Mikaw
    I like the mods. Never thought about mounting the Auxiliary tank yo the stand.
    26 May 2024 10:10 #899757 by Mikaw
    Your choice.
  • The following user(s) said Thank You: slmjim+Z1BEBE
    • slmjim+Z1BEBE
    • Topic Author
    27 May 2024 05:06 #899799 by slmjim+Z1BEBE
    Your choice.
    Perfect.  Thank You!
    We'll ask Mods to share addresses.
    Good Ridin'
    slmjim & Z1BEBE
    1974 Z1-A x2
    1975 Z1-B x2
    2009 ST1300A
    27 May 2024 13:35 #899819 by Wookie58
    Your choice.
    Perfect.  Thank You!
    Good Ridin'
    slmjim & Z1BEBE
    Done
    13 Jun 2024 14:56 #900682 by Mikaw
    Slmjim, I have sent a couple emails and no reply. Have you received them. Hope you and your family are well.
    • slmjim+Z1BEBE
    • Topic Author
    14 Jun 2024 05:22 #900703 by slmjim+Z1BEBE
    We replied to an email from
    <dock_manxx AT yahoo dot com>
    on June 28.  (The 'xx AT ' and 'dot' is our edit for your privacy).
    Was that you?
    Good Ridin'
    slmjim & Z1BEBE
    1974 Z1-A x2
    1975 Z1-B x2
    2009 ST1300A
