  • Page:
  • 1
  • 2
Seat 21 Jan 2023 18:19 #879133
  • allfixed
  • allfixed's Avatar Topic Author
  • Thank you received: 0
I'm looking for a good condition stock seat for my 78 KZ1000A
the flat type with a good pan would be great.
I'm currently using a KZ900 stock seat I will sell if I find the right seat.
Milwaukee wi.
Last edit: by allfixed.
Seat 22 Jan 2023 04:44 #879141
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
Are they not the same except for the cover?
Seat 22 Jan 2023 08:10 #879152
  • allfixed
Very close, mine is an early 900 seat the pan is a tad different it fits works fine and the cover pattern is different.
Milwaukee wi.
Seat 22 Jan 2023 14:20 #879170
  • hardrockminer
Perhaps all you need is a new cover.  They are fairly common.  Here is one source.
www.z1enterprises.com/seat-cover-kz1000-...Early/KZ1000-A2/1978
Seat 22 Jan 2023 16:03 #879177
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1854
‘76-‘77 Kz900A and the ‘77-‘78 Kz1000A all used the same seat. There are only two flat seat patterns. Z1 and the KzA’s up till 1978. If yours is different then it’s not original. The pans are different also. The Z1 pan has the lock latch in the center. The KzA’s it is off to the left side. LTD ‘76-‘80 pan and cover are stepped. Then you get into the D1 and D3 seat, flattish but a third pattern. Also the MKII is similar to the D’s without a sectioned side panel.
Last edit: by Mikaw.
Seat 23 Jan 2023 03:18 #879193
  • cmore
  • cmore's Avatar
  • Thank you received: 7
Fun fact - the 78 KZ1000 A model seat has a unique (78 only) pattern as seen in this image - current ebay item 275637727798 - It is similar in appearance to the Z1 pattern but different
Another 1978 A model difference as compared to the 1977 model is the addition of a spot welded seat rod catch
1976 & 1977 KZ900 and 1977 KZ1000 A had the same seat cover but different battery vent hose decals - see ebay item 203253161255
Last edit: by cmore.
Seat 24 Jan 2023 13:21 #879236
  • LukasLee
  • LukasLee's Avatar
  • Thank you received: 2
I have one that you may be interested in, I tried to PM you but I get a message saying something to the effect that I should contact the site administrator, when I try to contact him I get the same message. Any help would be appreciated.
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
Seat 24 Jan 2023 14:01 #879243
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1968
Use his email
This email address is being protected from spambots. You need JavaScript enabled to view it.
Seat 24 Jan 2023 15:43 #879252
  • Mikaw
  • Mikaw's Avatar
Attachment not found
Partzilla shows 2 part number 53001-119 and 53001-1009. Based on my research 53001-119 is correct for the Kz900/Kz1000 through 1978. Is it possible that the 1009 seat is the Canadian/EU model?
Seat 24 Jan 2023 16:40 #879256
  • allfixed
Thanks all
I purchased the one on ebay shown earlier in this post.
It's ok but a little scabby, I'd be interested in seeing others avail nicer.
Mine is a 78A as mentioned earlier it has the 3 rows of rectangles I'm looking for. I have a 900 seat to sell  with the rectangles down the center
this is the seat I have on my 781000A now
Milwaukee wi.
Last edit: by Street Fighter LTD.
Seat 24 Jan 2023 16:48 #879258
  • allfixed
This is the style I've seen on the 78 kz1000As  I've seen and I'm wanting for mine
Milwaukee wi.
Seat 24 Jan 2023 17:12 #879260
  • allfixed
What do you have? I get the same message when I try to pm you?
email me @ This email address is being protected from spambots. You need JavaScript enabled to view it.
Milwaukee wi.
  • Page:
  • 1
  • 2
