  • Page:
  • 1
  • 2
Wanted 77/78 1000a rear wheel 06 Jul 2021 11:57 #851391
  • ronnieV
  • ronnieV's Avatar Topic Author
  • Thank you received: 80
Wanted 77/78 kz1000 spoke wheel with disc brake in nice shape. Please text me 413-218-2024.
77 ltd1000 80 ltd1000 93 zr1100 zepher.02 red zrx 12r, 03 valkyrie (my couch) 65 olds 442
Wanted 77/78 1000a rear wheel 06 Jul 2021 13:58 #851401
  • DFIGPZ
  • DFIGPZ's Avatar
  • Thank you received: 109
I have a hub & new EBC floating rotor for rear of Disc brake KZ1000 with spoke wheel if you cannot find take off.
1984 GPZ 1100
1170 wiesco 10.5 cr
Larry Cavanaugh head
Bored Throttle bodies
Web .415in cams
Kerker K2 with comp baffle
RC Hp inj
Pogue Adj Regulator
VITON VALVE SEALS $22.00 SET OF 8 SHIPPED TO LOWER 48 PM ME.
Wanted 77/78 1000a rear wheel 07 Jul 2021 08:55 #851450
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 389
This is a hub & disc I bought in April from a member  "USA FOREVER" I did my resto work on it. Turned out nice.
But rims complete are tough to find, especially 77-78 specific only! Buy a $100-$200 nice 40 spoke ring, a set of $130 Buchanon SS spokes. Find someone to true it up $$??
This is why your looking for a complete rim!
Go on facebook and search the old  ebay "PAIDEN" out This is "Jake Cooper" on FB from Ohio.
He has a big stash of parts.
Still have a Kaw! 76 KZ900 Pro-Street.
And The Old Girl, Harley 75 FLH Electra Glide,
Wanted 77/78 1000a rear wheel 07 Jul 2021 11:41 #851453
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 816
Marty very nice.
Wanted 77/78 1000a rear wheel 07 Jul 2021 15:34 #851458
  • z1kzonly
  • z1kzonly's Avatar
Thanks Matt! I just passed it on to a guy who exports to Japan. After all said and done, and all my labor. I think I made $5.00 bucks! But I love doing this stuff, just to see how it turns out. I know your 76 is built to stock. But, did you see this item I restored? I cut the rusted wheel off and re-did the hub. I love polished aluminum, so this was the complete hub. I got $400 on ebay for this.
Good luck with your engine, It's tough you find bad parts. Maybe I would have tried to clean the small ends of that crank, polish with some fine grit, with high speed air or ? Along with new wrist pins. It won't have any bad rod knocks, if so you will know what it is. Or find a $100 dollar crank on ebay. They are so close and interchangeable. no problems. One of my drag / street bikes had a 1973 top case with the 73 VIN. And a 1978 lower case with all internals. That's how good the Kaw Factory built stuff and stayed in tolerance over the years.!
Here is that hub I did and sold, ready for a new rim & spokes.
Wanted 77/78 1000a rear wheel 07 Jul 2021 16:04 #851459
  • Mikaw
  • Mikaw's Avatar
I saw that sale. Another fine example of your quality.
Wanted 77/78 1000a rear wheel 17 Jul 2021 06:14 #851897
  • ronnieV
I'm told the early kz750 wheel will work is this true and if so do I need different spacers ?Does anyone have one of those? My project is at a stand still till I find one.
Wanted 77/78 1000a rear wheel 17 Jul 2021 11:04 #851911
  • Mikaw
  • Mikaw's Avatar
It claims to be the 750. 750 twin part 42005-048, 1000A is 42005-053. Bearings are the same between both but the axle is different. The spacers are also different
78 Kawasaki KZ 750 KZ750 B Twin rear back wheel them straight
Completed
Last edit: by Mikaw.
Wanted 77/78 1000a rear wheel 17 Jul 2021 14:28 #851924
  • ronnieV
I seen that , would I use the 1000 axle and spacers?
Wanted 77/78 1000a rear wheel 17 Jul 2021 16:12 #851931
  • Mikaw
  • Mikaw's Avatar
Appears the bearings and seals are the same so I’d guess the axle is a different length, another indication is the spacers are different. That makes me think it length and maybe the brake caliper mount is different thus requiring the different axle… I can’t tell you if the 1000A is longer or shorter. This is all just me talking out loud. Not much help be just my $.02
Wanted 77/78 1000a rear wheel 17 Jul 2021 16:19 #851932
  • Mikaw
  • Mikaw's Avatar
Here’s a side by side fishe I put a square around the different spacers. Your going to have to look at rear caliper mounting to decide more.
The following user(s) said Thank You: ronnieV
Wanted 77/78 1000a rear wheel 17 Jul 2021 16:33 #851938
  • Mikaw
  • Mikaw's Avatar
Here. The caliper mount on the 1000A doesn’t need a bush/sleeve.
EDIT: Number 4 on the 1000A is a caliper bracket bush/spacer. Sorry
  • Page:
  • 1
  • 2
