  • Page:
  • 1
TOPIC: Vm26ss carb body
Vm26ss carb body 24 Mar 2020 16:44 #821640
  • Gdizard
  • Gdizard's Avatar Topic Author
  • Member
  • Member
  • Thank you received: 0
Does anyone have one carb body for sale ?
Vm26ss carb body 24 Mar 2020 18:41 #821652
  • Scirocco
  • Scirocco's Avatar
  • Expert Boarder
  • Expert Boarder
  • Thank you received: 1134
What´s wrong with your carb body???
Vm26ss carb body 24 Mar 2020 18:49 #821655
  • Gdizard
  • Member
  • Member
The opening on the air cleaner side has a dent where someone must have dropped it .
Vm26ss carb body 24 Mar 2020 19:02 #821659
  • Scirocco
  • Scirocco's Avatar
  • Expert Boarder
  • Expert Boarder
This can be fixed/reformed with a rubber hammer and a suitable round plastic rod and some light Tabs!!!
Vm26ss carb body 24 Mar 2020 19:06 #821660
  • TexasKZ
  • TexasKZ's Avatar
  • Platinum Boarder
  • Platinum Boarder
  • Thank you received: 1056
Wasn't there a thread recently that showed how to do that?
Vm26ss carb body 24 Mar 2020 19:15 #821662
  • Gdizard
  • Member
  • Member
Would you only need a hammer ? I thought maybe some heat and a surface with the curve of the normal outside circle or curve.
Vm26ss carb body 24 Mar 2020 19:18 #821664
  • TexasKZ
  • TexasKZ's Avatar
  • Platinum Boarder
  • Platinum Boarder
A hammer and a mandrel. No heat.
The following user(s) said Thank You: Nessism, Gdizard
Vm26ss carb body 24 Mar 2020 20:09 #821668
  • SWest
  • SWest's Avatar
  • Moderator
  • Moderator
  • Thank you received: 1895
As long as the boot seals what's the problem?
Opinions expressed by me do not reflect those of the the staff or members
Last edit: by SWest. Reason: sp
Vm26ss carb body 25 Mar 2020 02:31 #821678
  • zed1015
  • zed1015's Avatar
  • Member
  • Member
  • Thank you received: 665
As mentioned that dent will come out with some careful manipulation from a plastic hammer and a round/curved mandrel.
The alloy is very malleable but don't use any heat as it's more likely to crack due to it being prone to "hot short".
Vm26ss carb body 25 Mar 2020 07:48 #821701
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Member
  • Member
  • Thank you received: 287
SWest wrote: As long as the boot seals what's the problem?
+1
Good Ridin'
slmjim & Z1BEBE
1973 Z1 x2
1973 Z1 "The Wounded Z" Resto project
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
  • Page:
  • 1
