  • Page:
  • 1
Another kwak tool! 21 Jan 2021 12:24 #842134
  • Sheath
  • Sheath's Avatar Topic Author
  • 05 17 1984
  • Thank you received: 14
Hey everyone! I've just been going through some of the tools I have in storage and I think I found another kawasaki factory tool that I didn't realise was one!!
Stamped on it is 57-001043
Another kwak tool! 21 Jan 2021 12:50 #842136
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
The number looks like 57001-243. #26 in the diagram below. Valve compressor adapter.
I think the part number wouldn't include the rest of the tool that looks like a C-clamp.
Part #2 sure adds some confusion. to me anyway.
www.partzilla.com/catalog/kawasaki/motor...cial-service-tools-b
The following user(s) said Thank You: Sheath
Last edit: by martin_csr.
Another kwak tool! 21 Jan 2021 14:36 #842138
  • Sheath
  • 05 17 1984
Good diagram :) I have another couple of the tools in the diagram too! ;)
Another kwak tool! 21 Jan 2021 16:01 #842140
  • martin_csr
That diagram is Special Tools B. There's also a Special Tools A diagram. In case you have other items that you need to identify. My 81 650-CSR doesn't have those diagrams. I've only seen them with the earlier KZ650s & Big Kaws.
Another kwak tool! 21 Jan 2021 20:24 #842144
  • krazee1
  • krazee1's Avatar
  • Thank you received: 197
I have a Special Tool Manual from July 15th 1974, it lists the Z1/Z2 valve spring compressor assembly as 57001-107 (doesn't break it down into 3 parts). The compressor assembly for the KZ400 is 57001-241, but it shows the adapter (57001-242) and the C clamp (57001-244) as separate items. Pretty cool manual with an applicability table in the front, then a section of special tool lists by model, how to use the special tools and an index. If it would be useful to members of the forum I would be willing to send it to someone to scan and add to the database. (I would like to have it back)
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
Another kwak tool! 22 Jan 2021 05:11 #842150
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1022
I would be interested.
The following user(s) said Thank You: Mikaw, krazee1
Another kwak tool! 22 Jan 2021 08:12 #842160
  • Kaylinator
  • Kaylinator's Avatar
  • Thank you received: 74
Sheath wrote: Good diagram :) I have another couple of the tools in the diagram too! ;)
The electro tester is cool, but THREE piston ring compressor sets? A search won't even turn up one.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
Another kwak tool! 22 Jan 2021 08:29 #842166
  • Sheath
  • 05 17 1984
Hee hee, I've got a few more factory bits! ;) my favorite item is definitely the vacuum gauges :) :)
Another kwak tool! 22 Jan 2021 09:06 #842169
  • krazee1
  • krazee1's Avatar
"I would be interested" PM sent
Thanks, Mike
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
Last edit: by krazee1.
  • Page:
  • 1
