  • Page:
  • 1
Auxiliary Fuel Tank 22 Oct 2020 10:21 #837492
  • Buzz Nichols
  • Buzz Nichols's Avatar Topic Author
  • Thank you received: 105
I couldn't bear to buy one, so I drilled a hole in the bottom of an aluminum water bottle and JB Weld-ed to it a 1/4" nipple attached to a ball valve and a barbed adaptor. Then I drilled a couple of small breather holes in the cap. A few feet of 1/4" fuel line hose and a barbed tee, and Bob's your uncle.
1978 KZ1000 LTD
Auxiliary Fuel Tank 22 Oct 2020 13:37 #837504
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1849
Good job. Just a note of caution. Try to keep the aux tank as close to the original height above the carbs as the original tank. The higher you raise it the more fuel pressure will increase.
Auxiliary Fuel Tank 22 Oct 2020 14:29 #837506
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1021
Mikaw wrote: Good job. Just a note of caution. Try to keep the aux tank as close to the original height above the carbs as the original tank. The higher you raise it the more fuel pressure will increase.
And don't mix it up with your water bottle!
Auxiliary Fuel Tank 24 Oct 2020 10:52 #837618
  • Mikaw
  • Mikaw's Avatar
Yike, great comment. I bet you’d only do it once!
  • Page:
  • 1
