  • Page:
  • 1
1980 KZ750 LTD H - help getting dust seal on to the caliper 21 Sep 2020 11:28 #835476
  • AnnihilAnt
  • AnnihilAnt's Avatar Topic Author
  • Thank you received: 2
Hey people,
Have been working the front brakes draining and cleaning and rebuilding. I'm installing the dust seal over the piston and man it's giving me such a hard time. Is there a trick or tool to get this bugger back in its groove? Thanks in advance for advice, everyone is so helpful here.
1980 KZ750 LTD H - help getting dust seal on to the caliper 21 Sep 2020 12:35 #835479
  • Bob Maximum
  • Bob Maximum's Avatar
  • Thank you received: 4
Not wanting to state the obvious but do you have the correct size? Coincidentally I did one also today on a 1000 LTD. It has 38mm pistons but some of these bikes/models are 40mm.
My method was to remove the dust seal retainer, fit the seal over the retainer, fit the seal over the piston, then install the piston in to the calliper with seal and retainer already on the piston, then push home the retainer.
Getting the seal over the piston should not be awkward at all.
1972 Kawasaki F8a bison with 350cc top end.
1975 Kawasaki F9c bighorn 350cc
1978 Kawasaki KZ1000 LTD
1984 Yamaha XT600
2006 Yamaha FJR 1300
The following user(s) said Thank You: AnnihilAnt
1980 KZ750 LTD H - help getting dust seal on to the caliper 21 Sep 2020 12:52 #835481
  • AnnihilAnt
Hey Bob,
It's the original piston and dust seal they looked good no pitting or scratches on the piston, so I didn't replace them and think the sizing is correct. This is my first bike, and therefore my first attempt at anything like this. Sounds like technique is going to be the winner. I'll try your method, thanks much!
1980 KZ750 LTD H - help getting dust seal on to the caliper 21 Sep 2020 17:29 #835502
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2674
I slide the dust boot over the piston, positioning it at the very bottom. Then install the lip of the boot into the mating groove in the caliper body and lastly push the piston into the bore.
1980 KZ750 LTD H - help getting dust seal on to the caliper 29 Sep 2020 06:04 #835838
  • AnnihilAnt
Thanks Nessism, this method worked for me, It also helps that I decided to replace the boots. Appreciate the advice.
  • Page:
  • 1
