  • Page:
  • 1
  • 2
TOPIC: JIS Screwdriver P2 or P3?
JIS Screwdriver P2 or P3? 24 Jan 2019 20:11 #797452
  • ERIK814
  • ERIK814's Avatar Topic Author
  • Member
  • Member
  • Thank you received: 3
I need a JIS screw driver to get to the carb holders. Two came in my tool bag and the larger one (~1/4 in diameter) fits the screw but I'm not sure if it is a P2 or P3. Does anyone know?
I need to purchase a shorter (stubby version?) since I have less than 6 inches between the air box and the carb holder.
Also, if you know of a good screw driver that is short I'm all ears.
1981 KZ 440 LTD Belt Drive (Late Model)
JIS Screwdriver P2 or P3? 24 Jan 2019 20:38 #797454
  • Member
  • Member
  • Thank you received: 2662
Here are a couple things I use for JIS bits on my carbs.............
The following user(s) said Thank You: ERIK814
Last edit: by 650ed.
JIS Screwdriver P2 or P3? 25 Jan 2019 05:09 #797463
  • Nessism
  • Nessism's Avatar
  • Thank you received: 1338
I believe those are #3 size.
JIS Screwdriver P2 or P3? 25 Jan 2019 06:14 #797464
  • Member
  • Member
Nessism wrote: I believe those are #3 size.
I agree. Best bet is to try the #3 and make sure it fits properly. Ed
JIS Screwdriver P2 or P3? 25 Jan 2019 08:21 #797472
  • SWest
  • SWest's Avatar
  • Moderator
  • Moderator
  • Thank you received: 1932
If they won't budge you need one of these.
Opinions expressed by me do not reflect those of the the staff or members
JIS Screwdriver P2 or P3? 25 Jan 2019 09:24 #797477
  • Member
  • Member
I HIGHLY recommend that before attempting to remove the carb holder screws you soak them for 3 days with Kroil. On my KZ650 I did that and the screws came out with no problem at all. Otherwise you run a very serious risk of either breaking the screws, breaking the cylinder head, or damaging the screw heads. I've seen postings where other folks have done that type of damage by trying to force those screws out. Ed
JIS Screwdriver P2 or P3? 26 Jan 2019 05:05 #797537
  • KZB2 650
  • KZB2 650's Avatar
  • Member
  • Member
  • Thank you received: 244
I replaced these with allen heads many a year ago.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
16/42 gearing X ring chain and alum rear JT sprocket....
The following user(s) said Thank You: OKC_Kent
JIS Screwdriver P2 or P3? 26 Jan 2019 05:58 #797538
  • Member
  • Member
I bought a BSA engine once and the screws that held the case covers on had been replaced with Allen head screws. Every one of the female threads in the engine that those screws fastened into were stripped! Remember that aluminum engine threads will always strip out before the steel screw threads, so if you use Allen head screws be very careful not to overtighten them because apparently that is very easy to do. Ed
JIS Screwdriver P2 or P3? 26 Jan 2019 13:56 #797574
  • ERIK814
  • Member
  • Member
Thanks for all this input.
I've been using Q-tips to apply Liquid Wrench all around the fasteners for a few days now. The top fasteners are blind but the bottom ones are exposed, so I've been hitting the back of the bottom fasteners with Liquid Wrench as well. I just bought a set of 1/4-inch JIS bits (#1 thru #3) as well as a ratchet set with a 3/8-inch drive to 1/4-inch bit adapter that should come mid- next week. The plan is too keep on applying Liquid Wrench every day until the bits /ratchet arrive, then take out the carbs and attempt to remove the fasteners. I also got some Loctite Blue 242 and plan to apply them to the bolts when I install the new holders.
Will let you know how it goes!
Last edit: by ERIK814.
JIS Screwdriver P2 or P3? 15 Mar 2019 09:42 #800382
  • TexasKZ
  • TexasKZ's Avatar
  • Platinum Boarder
  • Platinum Boarder
  • Thank you received: 1144
Update?
JIS Screwdriver P2 or P3? 03 Apr 2019 13:35 #801454
  • TheWhiteDevil
  • TheWhiteDevil's Avatar
  • Away
  • Member
  • Member
  • Thank you received: 4
I just recently purchased new JIS screwdrivers offline. Vessel is the company. Been using them for a month. Superb.
1975 KZ400
1981 KZ750
1984 GPZ750
JIS Screwdriver P2 or P3? 06 May 2019 17:41 #803428
  • rickycodie
  • rickycodie's Avatar
  • Member
  • Member
  • Thank you received: 0
i've bought the Vessel Impacta P2 and P3 from amazon. My opinion is that both are needed items for any japanese bike.
  • Page:
  • 1
  • 2
