What are you using as parts washer solvent?
- slmjim+Z1BEBE
03 Jun 2017 07:27 - 03 Jun 2017 07:35
Hi all,
We have a standard 30gal. drum-mount parts washer. The company that did the last drum/solvent swap is no longer in business, and everyone else we've talked to (Safety-Kleen and Crystal Clean) wants to put us on a recurring contract. Even the longest one year interval is huge overkill for us, as we sometimes don't use the washer for months at a time.
The tag on the existing drum indicates the solvent is petroleum naphtha.
Looking and asking around locally, we've had people say they run:
mineral spirits;
1,1,1 trichloroethane (yeah,... no,... much as we'd like to, not going there...) :dry: ;
kerosene;
and diesel.
Tractor Supply has this stuff, but it's pricey:
www.tractorsupply.com/tsc/product/crown-...r-5-gal?cm_vc=-10005
Our washer is used mainly for cleaning oily/greasy residue & crud from whatever it's on, mostly to get a part clean enough to work on it without trashing a workbench.
If you're running a petroleum-based solvent, what is it?
If you're running an aqueous-based solvent, are you satisfied with its performance, and;
are you seeing any rust, corrosion or other damage, to the drum, pump or sink caused by the water?
Thanks for y'all's thoughts.
Good Ridin'
slmjim & Z1BEBE
EDIT: Before someone asks, we can dispose of the existing naphtha free of charge at our .gov metropolitan HazMat facility.
mineral spirits;
kerosene;
and diesel.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 03 Jun 2017 07:35 by slmjim+Z1BEBE. Reason: P.S.
- retterath
Re: What are you using as parts washer solvent?
03 Jun 2017 10:01
I've got a 5 gallon bucket of mineral spirits / stoddard solvent with a tightly sealing lid.
03 Jun 2017 10:32
I use mineral spirits too. After use the sludge settles to the bottom so you can syphon off the clean stuff on top.
- TwoCam
02 Jul 2017 06:04
Mineral spirits is all I use at my shop in the parts washer. Has a low flash point, so little fire hazard and is inexpensive. Works just fine. If you know anyone with a waste oil heater... they will gladly take away the old solvent when ready to change out the fluid.
- Kray-Z
- I need more power Scotty....
03 Jul 2017 21:33
Stay away from diesel! Stuff is evil and skin exposure will shorten your time on earth. Doesn't clean well at all, and deteriorates with age into a smelly lot of dirty oily junk. I'd imagine kerosene to be similar. Mineral spirits (keep covered when not in use) is the much better option.
-Scott
-Scott
- Kidkawie
- I bleed premix
04 Jul 2017 03:47
You dont need to add all 30 gallons. Just add a little higher than the pickup tube.
I use that stuff from Tractor Supply now, theres about 7 gallons in my cleaner and I reserve fresh for carbs, etc.
When I worked at a heavy equipment shop we used mineral spirits. Great cleaner but can burn your hands a little when its new.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- ayeckley
04 Jul 2017 06:20
I highly doubt you can get trichloroethane even if you tried. Whoever you spoke with probably meant trichloroethylene. Still nasty stuff but not nearly as bad and as near as I can tell is still commercially available.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
- ThatGPzGuy
04 Jul 2017 10:19
Mineral Spirits is usually the best choice followed by kerosene. Difficult to find in bulk though.
20 yrs ago I bought 20 gallons at a filling station in Simi Valley, CA. for $4.00 a gallon. I wish I could find it somewhere here in GA.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- jdvorchak
16 Sep 2017 05:52
I use diesel fuel in my parts washer. As for health hazards, I wash my motorcycle parts in it, I don't take a shower in it. I do wear rubber gloves as you should with any solvent.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
John
83 KZ550M1
83 KZ1100LTD
Also own:
