Harbor freight lift, finally. 25 Mar 2016 15:45 #717349
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2609
Looks like my ceiling is tall enough. ;)
Motorcycle lift Harbor Freight coupon 27 Mar 2016 18:51 #717659
  • Olajoe
  • Olajoe's Avatar
  • Free at last
  • Thank you received: 17
Nice lift.
Timbox wrote: Just picked one of these up for the different bike projects that I seem to get into. Getting to the age that working on the floor is no longer what I like to do. Here is the coupon from Harbor Freight, I think it is a good deal.
www.harborfreight.com/1000-lb-Capacity-M...=mEmail_s1035_c4915c
Just make sure you have a trailer or truck and a way to get the lift loaded and unloaded. Comes in a small coffin like box.
Will be adding some pics of the JB weld patch of that cover. If that does not work then I will look into MIG/TIG or other patch.
Motorcycle lift Harbor Freight coupon 27 Mar 2016 19:02 #717664
  • MadShad
  • MadShad's Avatar
  • Thank you received: 8
Bolted on my wheel chock tonight, makes things much easier. I can now push the bike onto the lift and have it captured by the chock and held upright, making the process of strapping it down by myself easy.
Love it so far!
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
Motorcycle lift Harbor Freight coupon 22 Apr 2016 19:23 #722458
  • kzz1king
  • kzz1king's Avatar
  • Thank you received: 52
Which chock is that ? Thinking I need to make that addition to mine.
MadShad wrote: Bolted on my wheel chock tonight, makes things much easier. I can now push the bike onto the lift and have it captured by the chock and held upright, making the process of strapping it down by myself easy.
Love it so far!
Home built KZ1000 turbo setup
Motorcycle lift Harbor Freight coupon 22 Apr 2016 20:27 #722475
  • GPzMOD750
  • GPzMOD750's Avatar
  • Thank you received: 148
Harbor freight auto chock. About $40 regular price.
You can't use it on its own but it'll hold it stable long enough to get up on a paddock stand or ratchet down.
Motorcycle lift Harbor Freight coupon 28 May 2016 16:48 #729014
  • Timbox
  • Timbox's Avatar Topic Author
Been reading this post, I have a HF lift that I picked up a few months ago. I will have to do the wheel chock mod, that is a great idea! I even think I have one running around the shed and not being used. Great place for it. Without the chock it is something to get the tie downs to release without tipping too much.
Long time shade tree wrencher
KZ750 B3 (current Project)
03 B12S
09 KLR650
86 FJ1200
ZX14 (sold)
ZRX1200R (sold) Best bike I have ever owned, need another one
Motorcycle lift Harbor Freight coupon 29 May 2016 10:48 #729098
  • markerdown
  • markerdown's Avatar
I've been looking at these HF lifts for a long time. I got a 20% off coupon too.
The Need for Speed Never Dies
\\\\\\\'75 Z2 750
\\\\\\\'76 KZ900
\\\\\\\'73 Z1 900 restoration project
\\\\\\\'73 Cuda 340 restoration project
2018 Z900RS
Motorcycle lift Harbor Freight coupon 29 May 2016 17:38 #729145
  • tomsbadkz
  • tomsbadkz's Avatar
  • Thank you received: 38
i bought one a few months ago. the older model which is 68892. it has a c channel for the main frame stronger setup than the 69904. I also bought the wheel chock upgrade from them. drilled holes in the table with some shorter stainless carriage bolts works perfectly.
Attachment 20160523_160403-2.jpeg not found
Attachment 20160523_160436-2.jpeg not found
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Bored throttle bodies
Motorcycle lift Harbor Freight coupon 29 May 2016 17:40 #729146
  • tomsbadkz
my kz is also strteched out 13 inches. plenty long!!!
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Motorcycle lift Harbor Freight coupon 01 Jun 2016 12:46 #729525
  • Dr. Gamma
  • Dr. Gamma's Avatar
  • Thank you received: 664
I mounted up a Pingle removable wheel chock to my Harbor lift. Its nice and small compared to the others and its removable!!!! I use my lift for other things than just a motorcycle lift. With the chock removed, I have a nice large flat surface to work on.
Now you see it!!!!
Now you don't!!!
1986 RG500G 2 stroke terror.
Last edit: by Dr. Gamma. Reason: added more!!!!
